How to know the last update data for Scene?
bigpea
Post by bigpea »
in domoticz in a Lua script I can retrieve the last update data for a variable or a device:
updTime = uservariables_lastupdate['xxx']
updTime = otherdevices_lastupdate['yyy']
But I don't know if is possible to know the last update data for a scene.
It's possible?
Many thanks.
jvdz
Domoticz version: 4.107
Re: How to know the last update data for Scene?
Post by jvdz »
No it isn't possible as a Group or Scene is just a set of Devices with an accompanying action.
Jos
bigpea
Post by bigpea »
Ok thanks,
you are right.
I retrieved the data from the json:
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local config=assert(io.popen('curl http://192.168.0.1:8080/json.htm?type=scenes'))
local location = config:read('*all')
config:close()
local jsonLocation = json:decode(location)
--retrieve the data from idx 1
for i, singleScene in ipairs(jsonLocation.result) do
    if (singleScene.idx == '1') then
        lastUpdateScene = singleScene.LastUpdate
