Energy in dummy device in LUA
journeyman
Post by journeyman »
I have working Energy usage device (Dummy based on Pulse and ESP Easy).
In my home system I would like to se in IMperiHOME my daily usage. So the shortest way is to create another device
Bez tytułu.png (29.07 KiB) Viewed 5731 times
How in LUA can I take Daily usage from my first counter and put it to second "Daily" one?
supermat
Re: Energy in dummy device in LUA
Post by supermat »
I made something similar but with two tarif.
Sorry, it's in french :
https://matdomotique.wordpress.com/2017 ... f-virtuel/
journeyman
Unfortunately, completely I do not understand French but that is exactly what I need. Only if it will work with pulse counter from ESPEasy?
I would like to have insight into total consumption, monthly, daily, along with the enumeration of costs - divided into two fares. Tariff change me quite often.
journeyman
I try to use your script, I put my ID devices. but I get an error :oops:
 2017-03-07 11:09:00.279 Error: EventSystem: in Elektrownia: [string "function log(p_message)..."]:21: bad argument #1 to 'pairs' (table expected, got nil)
2017-03-07 11:09:12.790 Error: EventSystem: in Elektrownia: [string "function log(p_message)..."]:29: attempt to perform arithmetic on global 'EnergyImportLow' (a nil value)
supermat
Post by supermat »
OK I think it is because your "idxCompteurIntelligent" is new and it has now initial value, so it return a nil value.
For the first time, the new CompteurIntelligent need to be initialize.
Can you add these lines before : EnergyImport = EnergyImportLow + EnergyImportHigh
-- For the first time, the value are not initilize in the smart counter, we set 0 by default.
if(EnergyImportLow == nil)then
EnergyImportLow =0
EnergyImportHigh =0
EnergyExportLow = 0
EnergyExportHigh =0
PowerImport = 0
PowerExport = 0
It must be use only the first time the script is call.
journeyman
Thank you helped.
I ran once, then removed.
Now is:
"EventSystem: Script event triggered"
But do not change the meter reading, is still 0.0
journeyman
There was my mistake with one of ID.
Its look like it took to T2 all of my already taken 22kWh. I will make some test now :)
Thank you!
OK Its working perfect!
What is the easiest way to put some daily/monthly data of usage or costs to another dummy or tex device? To show it in some external system like ImperiHome?
supermat
Post by supermat »
You can show that directly in domoticz. Inside the device.
Abbadon
Post by Abbadon »
supermat wrote:You can show that directly in domoticz. Inside the device.
can you tell us more?
Abbadon
Post by Abbadon »
journeyman wrote:There was my mistake with one of ID.
Thank you!
idk if that possible in LUA, i made it in bash, take your counter IDX
Add dummy text sensor, take IDX
#!/bin/bash
data=`curl --silent -is "http://ip:port/json.htm?type=devices&rid=IDX" |grep "CounterToday" |sed 's/"//g' |awk '{print $3}'`
string="http://ip:port/json.htm?type=command&param=udevice&IDX=120&nvalue=0&svalue="$data"kWh"
curl --silent $string
make that script executable with
chmod +x filename.sh
and then add to cron like (every 1 min, for 5mins interval change first '*' with '*/5'
* * * * * sh /home/pi/domoticz/scripts/daily.sh
in imperihome add it, change icon and its ok.
ive made the same script which do the same every day at 23:55 and show me usage from last day (left usage is prev day, right 'this' day)
journeyman
Thats great! :)
Thank you!
But how can i split it in to T1 and T2? To make calculation and show "Today costs"
Abbadon
Post by Abbadon »
no idea, probably need to call database
Brutus
Post by Brutus »
How can I extract in LUA the daily usage of a energie sensor?
I want to extract the daily solar power generation and send it through a notification with maybe some other information.
A simple extraction like this code will not work because it gives me only the total energy and current power.
sEnergyPower, sEnergyTotal = otherdevices_svalues['Energie']:match("([^;]+);([^;]+)")
I can't extract the part from the French LUA because I don't understand it.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
journeyman
After yesterday update to Beta 3.8197 This counter with T1 T2 is not working anymore :?
Im getting this in log
2017-08-03 09:38:00.277 Error: EventSystem: in Elektrownia: [string "function log(p_message)..."]:21: bad argument #1 to 'pairs' (table expected, got nil)
What can I do to solve that? Its stop working after update :oops:
-- print("[HPHC] " .. p_message)
function getdevname4idx(deviceIDX)
 for i, v in pairs(otherdevices_idx) do
   if v == deviceIDX then
     return i
 return 0
DEBUG = false
local nomCompteurPrincipal = getdevname4idx(129) --OWL
local idxCompteurIntelligent = 133
local nomCompteurIntelligent = getdevname4idx(idxCompteurIntelligent)--HPHC
local nomHeureCreuse = getdevname4idx(134) -- Switch Heures Creuses
for deviceName,deviceValue in pairs(devicechanged) do
 if (deviceName==nomCompteurPrincipal) then
   -- On récupère la valeur du compteur unique => consEnergy
   ConsPower, consEnergy = string.match(otherdevices_svalues[nomCompteurPrincipal], "(%d+%.*%d*);(%d+%.*%d*)")
   log(ConsPower.."-"..consEnergy)
   --on somme les compteurs HP et HC => EnergyImport
   --http://www.domoticz.com/wiki/Upload_energy_data_to_PVoutput
   EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[nomCompteurIntelligent]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
   EnergyExport = EnergyExportLow + EnergyExportHigh
   log(" ----- PowerImport = " .. PowerImport .. " W");
   log(" ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
   log(" ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
   log(" ----- EnergyImport = " .. EnergyImport .. " Wh");
   log(" ----- PowerExport = " .. PowerExport .. " W");
   log(" ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
   log(" ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
   log(" ----- EnergyExport = " .. EnergyExport .. " Wh");
   --On calcule le delta avec le compteur actuel
   delta = consEnergy - EnergyImport
   --On ajoute le delta sur le bon tarif
   if (otherdevices[nomHeureCreuse] == 'On') then
     EnergyImportLow = EnergyImportLow + delta
     EnergyImportHigh = EnergyImportHigh + delta
   --On modifie le compteur intelligent
   commandArray['UpdateDevice'] = idxCompteurIntelligent.."|0|"..EnergyImportLow..";"..EnergyImportHigh..";0;0;"..ConsPower..";0"
jeroenkl
Post by jeroenkl »
Brutus wrote: Thursday 13 July 2017 0:44 How can I extract in LUA the daily usage of a energie sensor?
Hi Brutus,
Just came along your update and need the answer as well. Did you get an update or/and do you know to get the daily usage with LUA?
Hope you can help me.
regards,
Jeroen
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
@Brutus, @Jeroenkl
This is not in Lua but in dzVents 2.4. You can try the following
local Energy = domoticz.devices(Energie).rawData
domoticz.devices(Power).updateCounter(Energy[1])
domoticz.devices(TotalEnergy).updateCounter(Energy[2])
Of course this is somewhere in the middle of a dzVents script.
This works for me to parse all 6 values form the Electricity devicce of the P1 Smart Meter and update to different devices.
Correct me if I am wrong
Greetings McMelloW
