Xiaomi Mi Smart Home gateway integration or direct compatibility with Xiaomi ZigBee sensors?
Posted: Friday 03 March 2017 11:38
by Hedda
Xiaomi is known for making high quality items at low prices and they have recently started manufacturing different home automaton sensors.
http://xiaomi-mi.com/smart-home/xiaomi- ... -home-kit/
Would it not be very nice if Domoticz could support the Xiaomi Mi Smart Home gateway and Xiaomi ZigBee sensors out-of-the-box someday?
ยจ
Firstly wondering if there are plans for Xiaomi gateway integration in Domoticz? This apperars to be the gateway API but it is in Chinese:
https://louiszl.gitbooks.io/lumi-gatewa ... i/content/
Google Translate translation to English does look promesing though:
https://translate.google.se/translate?s ... edit-text=
I also read this guy created a basic test script to make Homey listen to the UDP API of the Xiaomi gateway, unfortunately it is unstable:
https://github.com/Joolee/nl.joolee.homey.aqara
Secondly wondering if direct pairing and communication with Domoticz to all Xiaomi wireless sensors is possible if have USB transmitter?
It sounds as if their sensors use different ZigBee specification, as some use ZigBee HA, while others use either SE, ZLL, or ZigBee PRO.
Unfortunatly for us Xiaomi does not fully follow ZigBee standards for its devices, instead they use different specifications & protocols.
I read that there is now a third-party integration for Home Assistant that works with all Xiaomi sensors, plugs and wall switches:
https://community.home-assistant.io/t/b ... ation/8213
As I understand this third-party integration even adds support for not just one but multiple Xiaomi Mi Smart Home gateways for redundacy.
That code from Xiaomi Hub component for HomeAssistant integration is available as open source on GitHub as developed by Rave (Lazcad):
https://github.com/lazcad/homeassistant
There also appers to be several Xiaomi Smart Home bindings available for OpenHAB also available as open source posted on GitHub, example:
https://github.com/openhab/openhab2-addons/pull/1660
Some third-party developers for Samsung SmartThings Hub have also developed support for Xiaomi's ZigBee sensors:
https://community.smartthings.com/t/xia ... beta/31948
https://github.com/erocm123/SmartThings ... s/erocm123
PS: I run Domoticz on a mini-PC, and was wondering if anyone have any tips of ZigBee USB dongles that supports all those specifications?
Re: Xiaomi Mi Smart Home gateway integration or direct compatibility with Xiaomi ZigBee sensors?
Posted: Friday 03 March 2017 11:43
by lamouette
You can start by reading the dedicated thread : https://www.domoticz.com/forum/viewtopi ... 17&t=11520
Posted: Friday 03 March 2017 12:59
by corbin
Hedda wrote: Would it not be very nice if Domoticz could support the Xiaomi Mi Smart Home gateway and Xiaomi ZigBee sensors out-of-the-box someday?
