need some help with node configuration
Posted: Friday 24 February 2017 21:19
Hi!
i use a raspberry pi 3 and a aeon z-wave gen5 module, i need a little help to make some settings.
How can i get node 16 in the picture to go straight to node 1, and not go trough other nodes, and also exclude other nodes to be able to connect through node 16?
Node 16 is a id doorlock, and according to the manufacuturer i must make a straight connection to the aeon stick, and no other nodes can go through the door lock node, this is just to prevent the batteries in the doorlock to run out of power to fast.
That battery drain has been a big problem,
The manufacturer also told me that polling should be deactivated, i have deactivated polling under hardware/settings, is this the only way, or is there some other settings that also needs to deactivate polling?
[img][/img]
[img][/img]
