I'm try to use fgs-222 relay switch with a classic button
every time that i push the button change the status of the lamp, but after release the but return to original status.
if i push the button 3 time faster the status change permanently, i think that there is some setting in domoticz or in fibaro relay that enable the permanetly change of the status with a single button pression.
thanks
fibaro fgs-222 and button change status
Re: fibaro fgs-222 and button change status
I guess you have to change the parameter of the switch (hardware > zwavedevice settings) and tell it to use a bi-stable switch instead of a momentary switch (pulse).
yes i have solved
thanks
thanks
