Link 2 domoticz systems
wm62
Domoticz version: 4.97
Post by wm62 »
Hi, i've got a straight question.
Is it possible to make a bridge between 2 domoticz systems, i've got one for my home automation , and one weather station.
Is it possible to read the values from this weather (domoticz) system to the first (home automation) system ?
Thx for your help
:D
amdavies
Domoticz version: 3.5877
Re: Couple 2 domoticz systems
Post by amdavies »
Yes this possible with the remote share option in settings and Domoticz - Remote Server in hardware.
I use this to link 3 pi's running Domoticz on together
Sent from my SM-N910F using Tapatalk
wm62
Re: Link 2 domoticz systems
Post by wm62 »
Great !! , gonna check this out now !
Thx
sincze
Domoticz version: 2024.4
Post by sincze »
amdavies wrote:Yes this possible with the remote share option in settings and Domoticz - Remote Server in hardware.
haha nice 3 pi's ;-)
I use it to monitor the hardware at a different location. :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
wm62
Post by wm62 »
Sorry can't get it to work but one question ,i've read this
This is caused by a mismatch in processor architectures, and specifically little/big endianness differences
Does this mean that the domoticz versions and also the jessie versions have to be the same ?
SweetPants
Post by SweetPants »
wm62 wrote:Does this mean that the domoticz versions and also the jessie versions have to be the same ?
No, I used to run 2 remote RPI's against a master on Ubuntu 14.04. Worked fine
amdavies
Post by amdavies »
The versions of domoticz does have to be the same I believe
pvm
Domoticz version: 4.10538
Post by pvm »
The architecture of your processors has to be the same (and domoticz versions). What hardware are you using?
amdavies
Post by amdavies »
For a short time while evaluating I had it running on a Windows 7 pc as a server, a pi b (original) and a pi b rev.2 before having a pi b+ instead of the pc
