I'm using last stable Domoticz Release with a Mosquitto Broker, so I'm using Virtual Sensors with "MQTT Client Gateway with LAN interface" as Hardware.
I've a fully working MQTT Switch, I'm able to switch on/off clearly; what I need to obtain is a feedback on the real switch status in order to know if switch set on/off in right way.
With MySensors Gateway Domoticz I can know when Switch is reachable or not; using MQTT how is possible to obtain the same feature?
I wish to disable switch command if MQTT device is not reachable...
How I can do it? I need an ACK with MQTT connection...how I can obatin it?
Thank you so much for support!
