Is it possible to compact more values in dummy-sensor devices
Posted: Tuesday 14 February 2017 18:36
by Greenwatts
No idea where to put this in a sub to keep/get a display/template which is at a glance clear or easy readable with many sensors
I want to start using Domoticz for my home energy system (heat and electricity) and not only monitoring but also some control (5 electric and 6 heat-sources) with all on LAN/IP avialable.
To get the values from the different modules in Domoticz is easy by a cron-script(s) but I have to split the output values of a module in many many, mostly single value dummy-sensor devices for Domoticz.
Is there not easy way to compact much, much, more sensor values in one dummy-sensor device or even a complete heat-meter in one dummy sensor device, as also the help of using colours for the name device bar, so that I not need 10-20 dummy sensor-devices for each module .
It's a long scroll on a smartphone >100+ dummy sensor devices
e.g Heat-meters (expanding to 12), i use two formats for these depending if it's from a heat generating with 12 outputs (5 modules) or heat release device is, 7 output values and the other are inputs for the release device which you also need to known for sendig a next command
To give an idea(kWth, day-kWhth, total-kWhth, Tin, Tout, Flow, airflow and for generation additional kWe, Day-kWhe, Total-kWhe, COP, day-COP, total-COP)
Coloured back ground for the device name bar as indicator for status?
e.g the flow in the heat circuit can be from waterpump in the mono-bloc heatpumps (two L/W heat pumpsb with own heat-circuit which can be coupled) or in island-mode from the auxiliary pumps in case the 3-way valves are switched
Buffer has also many output values as also several inputs, but can also run in different modes (scenario's =modes this are the main the input's not direct parameters) with a controlled heat release from the buffer by the heat-injector, e.g. modes are peaktime saving, WP defrost compensation, saving-E by reserving more from PV for recharging batteries for next island mode.
