Python Plugin SetPoint device
Posted: Monday 13 February 2017 19:45
by micha_pr
using 3.6694 - compiled version.
Python is running fine.
Tried to create a plugin with SetPoint Thermostat - but something is wrong...
I have added a SetPoint device, all seems to be ok.
Changing the value in UI - using the "Edit" button - the value will be changed in UI - and in database.
Requesting the value from Python it will not be changed.
Only after restarting domoticz the last value will be shown.
I use normal debug while HeartBeat for testing:
      Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
      Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
      Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
      Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
      Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
      Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
and get only the old value for sValue
2017-02-12 19:40:21.525  (hz11) onHeartbeat called
2017-02-12 19:40:21.525  (hz11) 'HardwareID':'9'
2017-02-12 19:40:21.525  (hz11) 'Port':'80'
2017-02-12 19:40:21.525  (hz11) 'Address':'127.0.0.1'
2017-02-12 19:40:21.525  (hz11) 'Version':'1.0.0'
2017-02-12 19:40:21.525  (hz11) 'HomeFolder':'/var/tmp/domo/dev-domoticz/plugins/Hzg/'
2017-02-12 19:40:21.525  (hz11) 'Mode3':'True'
2017-02-12 19:40:21.525  (hz11) 'Key':'Hzg1'
2017-02-12 19:40:21.525  (hz11) 'Mode6':'Debug'
2017-02-12 19:40:21.526  (hz11) 'Author':'nobody'
2017-02-12 19:40:21.526  (hz11) 'Name':'hz11'
2017-02-12 19:40:21.526  (hz11) Device count: 1
2017-02-12 19:40:21.526  (hz11) Device:           1 - ID: 7, Name: 'hz11 - Heizung2Set', nValue: 2, sValue: '25.00'
2017-02-12 19:40:21.526  (hz11) Device ID:       '7'
2017-02-12 19:40:21.526  (hz11) Device Name:     'hz11 - Heizung2Set'
2017-02-12 19:40:21.526  (hz11) Device nValue:    2
2017-02-12 19:40:21.526  (hz11) Device sValue:   '25.00'
2017-02-12 19:40:21.526  (hz11) Device LastLevel: 0
Value was set to 22 (as sample) - and is in SQLite database right.
How can I request the right sValue from Element?
Even if I update the nValue (19) for this Element in SQLite database, do not get the right one back...
7|9|0000009|1|hz11 - Heizung2Set|1|242|1|0|0|12|255|19|22.00|2017-02-12 19:21:17|7|0.0|1.0|0.0|1.0|||0|0|0||
UPDATE SOLUTION: (thanks to Dnpwwo):
Dnpwwo wrote:....That said, if you have a need to handle other things updating Domoticz values outside the plugin use:
Devices[x].Refresh()
to force synchronization as required.
Re: Python Plugin SetPoint device
Posted: Monday 13 February 2017 19:48
by micha_pr
NEXT PROBLEM:
SetPoint device (same for switch) have an option "Timer"
2017-02-13 20:02:01.915  Schedule item started! Name: hz16 - Heizung2Set, Type: On Time, ThermostatID: 18, Time: 2017-02-13 20:02:01
Timer is not updating the value - nothing happen, no event.
For Switch I will get an event:
2017-02-13 20:10:01.979  Schedule item started! Name: hz16 - Status, Type: On Time, DevID: 19, Time: 2017-02-13 20:10:01
2017-02-13 20:10:02.016  (hz16) Calling message handler 'onCommand'.
2017-02-13 20:10:02.016  (hz16) onCommand called for Unit 3: Parameter 'Off', Level: 15
How this can be solved for SetPoint device?
Any idea?
THANKS!
Posted: Monday 13 February 2017 21:38
by Dnpwwo
@micha_pr,
That might be a bug. I haven't done anything with timers and assumed they would update the same way that other parts of the system do.
I will have a look at it.
Posted: Thursday 16 February 2017 11:15
by Dnpwwo
@micha_pr,
I set a timer on a Domoticz device controlled by a Python plugin and the onCommand was called as I expected.
I got a 'Set Level' command with a level of 99 on a slider.
Can you retry?
Posted: Thursday 16 February 2017 14:21
by micha_pr
rechecked (with same build) with timers:
FOR SWITCH:
2017-02-16 14:10:01.285  Schedule item started! Name: hz20 - Status, Type: On Time, DevID: 13, Time: 2017-02-16 14:10:01
2017-02-16 14:10:01.292  (hz20) Calling message handler 'onCommand'.
2017-02-16 14:10:01.292  (hz20) onCommand called for Unit 3: Parameter 'On', Level: 15
2017-02-16 14:12:01.304  Schedule item started! Name: hz20 - Status, Type: On Time, DevID: 13, Time: 2017-02-16 14:12:01
2017-02-16 14:12:01.337  (hz20) Calling message handler 'onCommand'.
2017-02-16 14:12:01.338  (hz20) onCommand called for Unit 3: Parameter 'Off', Level: 15
FOR SETPOINT DEVICE:
2017-02-16 14:12:58.954  Hardware Monitor: Fetching data (System sensors)
2017-02-16 14:13:01.314  Schedule item started! Name: hz20 - Heizung2Set, Type: On Time, ThermostatID: 12, Time: 2017-02-16 14:13:01
2017-02-16 14:13:01.963  (hz20) Calling message handler 'onHeartbeat'.
So, for setpoint device do not get anything...
Attached a simple plugin (have removed all not needed code - it will only add the devices and log)
plugin.txt
plugin.py (please rename) for testing setpoint device with timer
(4.44 KiB) Downloaded 201 times
I hope you can find out the issue ;)
Thanks!!
Posted: Thursday 16 February 2017 14:32
by Dnpwwo
@micha_pr,
It appears that SetPoint devices have their own special code in Domoticz which is why it is not being picked up.
I will look into it.
Posted: Saturday 18 February 2017 11:51
by Dnpwwo
@micha_pr,
Pull Request #1242 has thermostat support built in. Once that is merged you shoud retry.
From the script you attached it looks like youare planning on doing socket and HTTP handling yourself. Do you realise the plugin framework has support for those built in?
Have a look at the Transport, Connect and Send commands on the help page http://www.domoticz.com/wiki/Developing_a_Python_plugin
Posted: Sunday 19 February 2017 20:01
by micha_pr
nice, will try it when available :)
you are planning on doing socket and HTTP handling yourself
I will try of course to use features from plugin.
Need the IP address and port setting for the external unit, managing the heating componets.
Wanted to try at first "regular" method, then switch step by step to plugin ;)
In this time it is a Python script running with cron job - but I think it can be more interesting for other users if it will be a plug&play solution using your standard python plugin.
Will tell you when Setpoint is working ;)
Thank you!
Posted: Monday 20 February 2017 20:26
by micha_pr
Setpoint device is working now, thanks!
But the other one (type 70 - Heating / Zone) have same issue, sorry.
I can update the device setting a new sValue, but it will not make any call if user will change the setpoint.
This device will be used to show the current temperature and setpoint + the current mode (custom, auto, permanent overwrite)
You can try same script as before.
Thanks again!
Michael
Posted: Wednesday 22 February 2017 10:07
by Dnpwwo
@micha_pr,
I'm going to need more detail, hardware type 70 is:
	HTYPE_OpenWebNetTCP,		//70
that doesn't seem to line up with what you are saming about heating (although I could be wrong!)
Posted: Wednesday 22 February 2017 15:18
by micha_pr
Yes, maybe that in detail it is different ;)
I can update such device in normal case via JSON request (current solution - created via Hardware-evohome-zone) like
http://[IP]:8080/json.htm?type=setused&idx=547&name=Thermostatxyz&description=&setpoint=16&mode=PermanentOverride&until=&used=true
Then the value will be changed.
Of course can also request the values.
With current device created by Python plugin would be needed same functionality ;)
THANKS!
Posted: Thursday 02 March 2017 19:21
by micha_pr
Dnpwwo wrote:@micha_pr,
Do you need something else from me? How I can help to integrate the device?
Posted: Wednesday 08 March 2017 14:35
by micha_pr
is there a chance to add this device into the Python plugin?
Or will be the best way to handle it via JSON scripting inside the script?
It's really a good add-on element for handle a thermostat for checking mode, setpoint and current temp of the device.
Michael
Posted: Friday 14 April 2017 16:30
by barbaar
Can you share your latest code? I'm thinking about creating a plugin for the Tado Thermostat, and this would be a great jumpstart ;)
Posted: Tuesday 18 April 2017 20:29
by micha_pr
I made a Homematic plugin, but because of missing "type 70 - Heating / Zone" have stopped.
Maybe will solve this with additional JSON call for adding the device - without the Heating/Zone it is not very comfortable.
In this time the door/window handle control (open/closed/tilted) is working fine, but didn't make the right symbols for this... (3 state)
I think it does not help for Tado Thermostat, because Homematic is another standard...
Michael
Posted: Friday 21 April 2017 12:06
by Dnpwwo
@micha_pr,
I had another look at this and I think the problem is that Type 70 is not valid. The Type field maps on to the values in this file https://github.com/domoticz/domoticz/bl ... trx.h#L795 and valid thermostats types are (assuming my hex to decimal conversion is correct):
  • 64 - Thermostat1
  • 65 - Thermostat2
  • 66 - Thermostat3
  • 67 - Thermostat4
  • 72 - Radiator1
maybe you should try one of those. Valid SubTypes are shown as well.
Posted: Friday 21 April 2017 16:18
by micha_pr
Hmm....
Maybe my fault.... with this id.
Creating it with "json.htm?type=createevohomesensor&idx="+hwidx+"&sensortype=70"
in database looks like:
Thermostat - ID
Thermostat - ID
Any idea?
Michael
Posted: Tuesday 25 April 2017 16:13
by micha_pr
Dnpwwo wrote:maybe you should try one of those.
Have rechecked the suggested device IDs - does not help:
Here are only switches present.
Only the "needed" device "70" have the "Set" option (Set setpoint)
This is the one working device - see above, you made it working.
Type 70 is defined here:
https://github.com/domoticz/domoticz/bl ... pes.h#L252 - if this help...
Michael
