Disable Block not working
EDsteve
Post by EDsteve »
i disable a block via right click "disable block". It changes it's color. I save the event.
But the block still gets executed. Is that just me or a general problem?
disable block.JPG (164.67 KiB) Viewed 1490 times
Domoticz:
Version: 3.6562
Build Hash: 974bc54
Runs on a NanoPi With Jessie
Not a serious issue but annoying. Hope there is a fix for it. Or do i have to give permissions manually to a folder or so?
THX
ED
PHIL63
Re: Disable Block not working
Post by PHIL63 »
Same for me :(
Dlanor
Post by Dlanor »
I have the same sort problem. I have deleted two parts of the blocky script and saved the script. The old deleted parts are still executed.
Domoticz| Zigbee | SONOFF
Dlanor
Post by Dlanor »
Dlanor wrote:I have the same sort problem. I have deleted two parts of the blocky script and saved the script. The old deleted parts are still executed.
The following has worked for me and solved the problem. See the last post from the top from Gizmocuz:
CHRPIE:
Open your chrome browser, enable the development console (F12 under windows)
Go to the network tab, refresh the page, on one of the items in the network tab, press right mouse, from the popup menu choose 'clear browser cache'
(or just clear the appcache and browser cache
PHIL63
Post by PHIL63 »
the problem is always on.
I try to clear cache but nothing works.
All disabled blocs are running by domoticz like if they are not disabled.
