Door Switchtype and Invert value
Posted: Sunday 12 February 2017 16:11
Hi, been away from Domoticz/MySensors for a while because I was (still have) trouble keeping Domoticz running with MySensors. I belive that I had a problem with my MySensors Serial Gateway.
Now I have a new one and the initial test seems to show that it is working now. (I will return to this topic later on.)
How ever. Now when Im thinking about start planing my MySensors net again I have a couple of questions.
1: Is there no way to select a "Switch Type" that can not be controlled from Domoticz, ie is not clickable in Domoticz ? The typical use would be a door. Many of us have door sensors but very few (I belive) have the ability to open/close these doors from Domoticz. I know that I can choose "Protected" in the Edit Switch menue but that is only half a solution.
2: Is there a way to Invert the value that Domoticz get. If Domoticz recives an "switch on" command from a sensor but that in the real world actually means OFF. Could compensate for NC / NO switches. (In MySensors-sensors I could do this in the Arduino code but in RFXcom i can not)
Thanks again for a great Controller and a great community.
