extract old value with json
Posted: Sunday 12 February 2017 15:21
i try to extract with json old value from gps sensor. The data is a text string (idx 1 -> latitude and idx 3 -> longitude).
i receive only the last value, but i would get all the values between two date. I don't understand how i can do that
Thank for your help
Thank for your help
root@raspberrypi:/home/pi/domoticz/scripts# cat extract.php
#!/usr/bin/php
<?php
$json_string = file_get_contents("http://192.168.1.17:8080/json.htm?type=devices&rid=3");
$parsed_json = json_decode($json_string, true);
$test_link = "/home/pi/domoticz/scripts/test_1.txt";
$test_data = fopen ($test_link, "w+");
fwrite ($test_data, print_R($parsed_json, TRUE));
fclose ($test_data);
root@raspberrypi:/home/pi/domoticz/scripts# ./extract.php
root@raspberrypi:/home/pi/domoticz/scripts# cat test_1.txt
Array
[ActTime] => 1486907791
[ServerTime] => 2017-02-12 13:56:31
[Sunrise] => 06:41
[Sunset] => 17:03
[result] => Array
[0] => Array
[AddjMulti] => 1
[AddjMulti2] => 1
[AddjValue] => 0
[AddjValue2] => 0
[BatteryLevel] => 255
[CustomImage] => 0
[Data] => 5.440743
[Description] =>
[Favorite] => 0
[HardwareID] => 3
[HardwareName] => GATEWAY
[HardwareType] => MySensors Gateway USB
[HardwareTypeVal] => 41
[HaveTimeout] =>
[ID] => 00000302
[LastUpdate] => 2017-02-04 12:06:42
[Name] => Longitude
[Notifications] => false
[PlanID] => 0
[PlanIDs] => Array
[0] => 0
[Protected] =>
[ShowNotifications] =>
[SignalLevel] => -
[SubType] => Text
[Timers] => false
[Type] => General
[TypeImg] => text
[Unit] => 1
[Used] => 1
[XOffset] => 0
[YOffset] => 0
[idx] => 3
[status] => OK
[title] => Devices
