Daily back-up to external hdd scripts error message
hendrikenrenny
Post by hendrikenrenny »
I just installed a fresh SD card with Rasbian Jessie and the latest version of Domoitcz after the SD got corrupted. Happy that I had the script running for daily backups, so the loss of data was almost nothing.
In the fresh installation, I installed the script again (see https://www.domoticz.com/wiki/Daily_bac ... ternal_hdd) by copying the script in the /pi/domoticz/scrips/ directory, filling in the right IP addresses etc, ran the chmod command (no error messages). However, when I want to execute the script (sudo /home/pi/domoticz/scrips/domotic_backup.sh), the message says:
The script is with the correct name in the correct folder, so that's not the problem:
Does anybody knows what is wrong and how to solve this?
thnx
jvdz
Domoticz version: 4.107
Re: Daily back-up to external hdd scripts error message
Post by jvdz »
Have you set the Execute flag with chmod +x for the file?
Jos
hendrikenrenny
Yes, and I also tried chmod 777 ...
hendrikenrenny
Got it working again. Started the whole procedure from the start.
Still don't know what went wrong though...
Hendrik
