Aeotec HEM Gen5 (one clamp)
Posted: Friday 10 February 2017 18:37
by GSV3Miac
I've installed this using open z-wave and a ZME EUZB1 to talk to it, but whatever I send by way of config commands, domoticz only wants to show me Amps, Volts, Watts (and Watts again) .. in theory the device is sending me KwHr, and Va/VaHr too, but I can't see how to get at them.
I also note that the 'log' graph in Domoticz seems to have a hard-wired Y minimum of zero - since Watts can go negative (there is a PV system feeding the meter backwards!) I'd like a lower limit which allowed for negative values (or maybe I just need a separate graph, although that would be a bit of
a kludge).
Update:
After installing the latest beta, and restarting everything (PC included) I am now seeing a power meter and an energy meter (both), and if I ask for command value 63 I also get devices for Volts and Amps, but no obvious way to get at reactive power/energy (which is supposed to be there). Also every time I restart, the parameters are all reset to some default value (absolute energy, enabled 'report only on change', and the group 1/2 reporting values set to 2 and 1 respectively - is there some way to STOP it doing that??
