I'm using 2 minimotes.
With pass2php scripting they do exactly what I want depending on variable stuff.
Example button 2 long press: Wake nas, switch kodi on, switch amp on, switch tv on, set amp to input kodi. Switch lights on if dark. Of course all done only when needed.
<?php
if(apcu_fetch('nas')=='Off')shell_exec('/home/pi/wakenas.sh');
if(apcu_fetch('skodi')=='Off')sw('kodi','On');
if(apcu_fetch('sdenon')=='Off')sw('denon','On');
if(apcu_fetch('stv')=='Off')sw('tv','On');
if($zon<10&&(apcu_fetch('stvled')=='Off'||apcu_fetch('skristal')=='Off')){sw('tvled','On');sw('kristal','On');}
$ctx=stream_context_create(array('http'=>array('timeout'=>2)));
for($x=0;$x<=50;$x++){
usleep(500000);
$denon=json_decode(json_encode(simplexml_load_string(file_get_contents('http://192.168.2.4/goform/formMainZone_MainZoneXml.xml?_='.time(),false,$ctx))),TRUE);
if($denon['ZonePower']['value']!='ON'){
lg('Denon '.$x.' Zonepower != ON');
file_get_contents('http://192.168.2.4/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON&cmd1=aspMainZone_WebUpdateStatus%2F',false,$ctx);
}else{
if($denon['InputFuncSelect']['value']!='KODI'){
lg('Denon '.$x.' InputFuncSelect != KODI');
file_get_contents('http://192.168.2.4/MainZone/index.put.asp?cmd0=PutZone_InputFunction/DVD',false,$ctx);
}else{
lg('Denon '.$x.' OK');
sleep(1);
file_get_contents('http://192.168.2.4/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON&cmd1=aspMainZone_WebUpdateStatus%2F&ZoneName=ZONE2',false,$ctx);
break;
button 2 short press: Put kodi in pause and light one of the lights in the kitchen (depending on hour of day). Second push, put kodi in play and switch off other lights downstairs.
<?php
$kodi=apcu_fetch('skodi');
$wasbak=apcu_fetch('swasbak');
$werkblad=apcu_fetch('swerkblad');
if($kodi=='On'){
file_get_contents('http://192.168.2.7:1597/jsonrpc?request={"jsonrpc":"2.0","id":1,"method":"Player.PlayPause","params":{"playerid":1}}',false,$ctx);
$properties=json_decode(file_get_contents('http://192.168.2.7:1597/jsonrpc?request={"jsonrpc":"2.0","method":"Player.GetProperties","id":1,"params":{"playerid":1,"properties":["playlistid","speed","position","totaltime","time","audiostreams","currentaudiostream","subtitleenabled","subtitles","currentsubtitle"]}}',false,$ctx),true);
if(!empty($properties['result'])){
$prop=$properties['result'];
if($prop['speed']==0){
if($zon<100){
if(time>strtotime('7:00')&&time<strtotime('21:00')){
if($wasbak=='Off')sw('wasbak','On');
}else{
if($werkblad=='Off')sw('werkblad','On');
else andereuit();
}else{
if($wasbak=='On'||$werkblad=='On')andereuit();
else{
if($zon<100){
}else{
function andereuit(){
$items=array('pirkeuken','pirgarage','pirinkom','pirhall');
foreach($items as $item)
if(apcu_fetch('s'.$item)!='Off')
ud($item,0,'Off');
$items=array('eettafel','zithoek','garage','inkom','hall','keuken','werkblad','wasbak','kookplaat');
sw($item,'Off');
The minimote up stairs handles a sleep switch. One button for sleep, one to wake.
Button 1 sleep:
<?php
if($status=='On'){
if(apcu_fetch('sachterdeur')!='Open'){sw('deurbel','On');telegram('Opgelet: Achterdeur open!',false,2);die();}
if(apcu_fetch('sraamliving')!='Closed'){sw('deurbel','On');telegram('Opgelet: Raam Living open!',false,2);die();}
if(apcu_fetch('spoort')!='Closed'){sw('deurbel','On');telegram('Opgelet: Poort open!',false,2);die();}
if(apcu_fetch('sbureeltobi')=='On'){sw('deurbel','On');telegram('Opgelet: bureel Tobi aan!',false,2);die();}
if($Weg!=1){apcu_store('Weg',1);apcu_store('tWeg',time);}
if(apcu_fetch('sGroheRed')=='On')double('GroheRed','Off');
if(apcu_fetch('sdampkap')=='On')double('dampkap','Off');
if(apcu_fetch('sluifel')!='Open')sw('luifel','Off','zonneluifel dicht');
if(!$auto)sw('lichten_auto','On');
if(apcu_fetch('spoortrf')=='On')sw('poortrf','Off');
Button 3 wake:
<?php
if($Weg!=0){apcu_store('Weg',0);apcu_store('tWeg',time);}
if(apcu_fetch('shall')=='Off')sw('hall','On');
Visual confirmation is there. Light upstairs switches off/on to confirm the action.
With scripting, only your imagination is the limit of the system.
