Vitrum
airluck
Vitrum
Post by airluck »
Hi all, I'd like to buy virtum devices (http://www.switchtovitrum.com/) but the homemaster kit is too expensive so I'd like to build my own home master with domoticz and Aeotec USB Z-Stick Controllore S5 ZW090-C - Z-Wave. Vitrum is a Z-wave tecnology. Do you have any feedback with these devidces?
mlamie
Domoticz version: 3.5877
Re: Vitrum
Post by mlamie »
If z-wave devices are supported within Domoticz depends. Domoticz uses the OpenZwave library. I had a quick look and do find there products in the OpenZwave library. So they will work.
http://www.openzwave.net/device-database
If they doesn't work you can add the devices as written here: https://github.com/OpenZWave/open-zwave ... ng-Devices
I also did find them in the zwave databases under Think Simple Srl:
http://products.z-wavealliance.org/Sear ... Simple+srl
http://www.pepper1.net/zwavedb/?sort=na ... ric_class=
Changes are small it doens't work.
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
airluck
Re: Vitrum
Post by airluck »
Ok thanks a lot. I've see the xml file and found vitrum inside, but I've never tried them before. I suppose noone here tried that configurazione. I saw that Fibaro support vitrum but I don't have evidence if it is based on OpenZwave or what.
