os.time with %X
Posted: Wednesday 08 February 2017 6:39
by Mikey
I have multiple scripts where I use the time, but I normally use the time like this:
dayNow = tonumber(os.date('%w'))
hourNow = tonumber(os.date('%H'))
Within this I use integers to use the time like this:
elseif ((dayNow > 0) and (dayNow < 6)) and (((hourNow > 23) and (hourNow < 0)) or ((hourNow >= 0) and (hourNow < 7))) then
But now I would like to make it different with the %X, means:
But how can I use the %X? I found an example for '23:48:10', but how can I use this in script? Something like this does not work.
Thank you very much for your help.
Re: os.time with %X
Posted: Wednesday 08 February 2017 8:47
by Nautilus
Well, it might work with
if your script happens to run on that exact second
But I doubt you'd be that lucky. Maybe it is better to start with explaining what you are trying to accomplish as I have a hunch you might be going at it from a wrong direction
You can easily add a condition for minute by adding something like
minuteNow = tonumber(os.date("%M"))
and use it as a condition on time scripts (which trigger each minute), but I cannot think of any situation where knowing the current second would "add value" in accomplishing some task with Domoticz...
Re: os.time with %X
Posted: Wednesday 08 February 2017 8:58
by Mikey
Thanks for your reply. Actually I would like to do two things:
1. Trigger a switch to turn on at this time to make a back up. I want to turn on the switch at a time and turn the switch off again after two minutes.
2. I want to trigger a motion sensor and turn on a light when there's motion. But I want to do different scenes if there's different daytime. I already have this script, but I only trigger it with days and hours like:
if (globalvariables['Security']) == 'Disarmed' or devicechanged['Dummy Disarmed'] == 'On' then
if ((otherdevices['Bewegungssensor_WZ'] == 'On' and tonumber(w) < 20) and otherdevices['Licht_WZ'] == 'Off') then
commandArray['Licht_WZ'] = 'On'
print('Erste Moeglichkeit')
elseif ((otherdevices['Bewegungssensor_WZ'] == 'Off' and tonumber(w) < 20) and otherdevices['Licht_WZ'] == 'On') then
print('Zweite Moeglichkeit')
if (((dayNow > 0) and (dayNow < 6)) and ((hourNow >= 7) and (hourNow < 23))) then
commandArray['Licht_WZ'] = 'Off AFTER 3600'
print('Es ist Wochentag zwischen 7 und 23 Uhr')
commandArray['Licht_WZ'] = 'Off AFTER 300'
print('Es ist Wochentag zwischen 23 und 7 Uhr')
elseif (((dayNow == 0) or (dayNow == 6)) and ((hourNow >= 7) and (hourNow < 23))) then
print('Es ist Wochenende zwischen 7 und 23 Uhr')
elseif ((dayNow == 0) or (dayNow == 6)) and (((hourNow > 23) and (hourNow < 0)) or ((hourNow >= 0) and (hourNow < 7))) then
commandArray['Licht_WZ'] = 'Off AFTER 1200'
print('Es ist Wochenende zwischen 23 und 7 Uhr')
But I would like to trigger it more exactly.
Do you have any idea
Re: os.time with %X
Posted: Wednesday 08 February 2017 9:18
by Nautilus
Mikey wrote:Thanks for your reply. Actually I would like to do two things:
For this I would add the minute condition mentioned in the previous post. Lua time scripts run every minute (usually right after the minute changes). You can add an off delay of two minutes to the switch or use the same script to accomplish the "off" command. However, cannot see any benefit of having the dummy switch in Domoticz for this. I'd just run the backup script and that's that. If you want to keep the dummy, you can add a schedule for the switch as well (turn on/off at certain time)
Mikey wrote:2. I want to trigger a motion sensor and turn on a light when there's motion. But I want to do different scenes if there's different daytime. I already have this script, but I only trigger it with days and hours like:
Probably you mean the trigger is a motion sensor and action is turning on the light? This needs a
device script that triggers exactly when the motion sensor turns on (/ or off in case you need). It would be something like:
if devicechanged['Bewegungssensor_W'] == 'On' and otherdevices['Licht_WZ'] == 'Off' then
if dayNow > 0 and dayNow < 6 and hourNow >= 7 and hourNow < 23 and minuteNow > XX and minuteNow < XX then
Maybe you do not need the minute condition anymore when the script runs only when motion sensor is active?
So, if you want to react on device change use a device script with "if devicechanged..." condition at the start and additional time based condition to have a different action based on the current time. Then if you want to run or check something each minute, use a time script....
Re: os.time with %X
Posted: Wednesday 08 February 2017 10:36
by Mikey
Thanks Nautilus
I need both. I turn on the light when theres motion. Then I turn off the light when there has been no motion for a meaning time. But the meaning time is different for the different daytimes. I did it like you mentioned above. Now I can try to add minutes. But it makes the script very complicated. That's why I wanted to write it in the "23:58:00" format or similar. This would make the script much easier to read. Isn't there a possibility?
Re: os.time with %X
Posted: Wednesday 08 February 2017 11:20
by Nautilus
Mikey wrote:Thanks Nautilus
Surely there's some way but I have not tried to use that type of time in my scripts. One option would be to turn the time to seconds from midnight. e.g:
function currentTimeInSeconds()
s = os.time()
hours = string.sub(s, 12, 13)
return (hours * 3600 + minutes * 60 + seconds)
and then use this number in your scripts:
currentTime = currentTimeInSeconds()
if currentTimeInSeconds >= 86280 then
But still, I think seconds are too detailed to have any meaningful use in this type of scripts, minutes should be enough.
You could also add some dummy switches and add schedules for them to go on/off at certain times and then base the motion detection actions on the state of those dummy switches. Also, I don't think it looks that much complicated if you have a condition:
compared to
Re: os.time with %X
Posted: Wednesday 08 February 2017 11:58
by Mikey
Perfect, I will try that, thanks a lot
