Hi guy's.
My first post here, and I've been searching for someone with this same problem, but no luck so far.
I'm running Domoticz on an RPi3 with RFXtrx433E. I've also added my Philips Hue lights to my Domoticz.
What I'm trying to do, is to control my Philips Hue lights with an RF433 switch.
I'm using this Nexa WT-2 wallmounted switch right now: https://www.nexa.se/vara-produkter/syst ... sandare/wt
This way, I can control the on/off function of the Hue lights with an actual physical wall switch (which is fantastic), but, what I'm wondering, is if it also would be possible to use the dimmer function in the wall switch to dim the Hue lights as well?
What do you think, would this be possible? And I'm just not doing this correct?
Should maybe also mention that I'm very new to Domoticz, but really love what I've seen so far.
RF433 On/Off/Dimmer switch to control Philips Hue lights.
