Hi All,
After searching for a long time i still have not found an answer; "how to pair the SHS-53000 radiator valve to my RP/RFLink running on Domoticz".
I tried all logical possibilities:
1. Adding the remote by learning (Learn Light/Switch). The remote is detected, but controlling it, gives no result on the valve.
2. Maualy creating a RFLink Device (with the command line). The remote is also detected, but again controlling it, gives no result on the valve.
3. Adding the remote manually (Manual Light/Switch). Same problem.
4. Tried the command line in the RFLink Loader. According to the instruction viewtopic.php?t=13742 Again, same problem.
Somehow the signal / command from the RFLink does not reaches the valve. Can anybody help?
Thanks in advance.
Adding Smartwares SHS-53000
Barth
- Domoticz version: Latest
Domoticz on Raspberry Pi 3 with RFLink Gateway (433 MHz en NRF 2,4GHz) and EnOcean USB 300.
