Amplifier and speaker protection
Posted: Friday 03 February 2017 12:03
I am a DIY HiFi builder. Many of these "experimental" systems suffer from a turn on "thump" through the speakers as the different parts of the electronics settle down after power on.
My System uses separate HomeEasy receivers to power on the main hi-fi stack, and separate HomeEasy receivers to power on the power amplifiers (which have a built-in 3- sec delay...not nearly enough).
The idea I have is that when I power on the hi-fi-stack, via the remote control and/or Domo, then after 10 seconds Domo will power-on the amplifiers. At turn-off of the hi-fi-stack, Domo will power off the main amplifiers. So, no more thumps through expensive speakers.
The problem I have is information overload. How to do this (simple?) thing through Domo? Do I go in for PHP scripts, can I use the built-in features of Domo..just where to start?
Any advice or examples of how to do this gratefully received. The problem above is relatively common in Hi-fi and frequently solved with extra hardware, cabling and boxes. The Domo solution, assuming it is realistic and possible, should be much nicer and much more flexible.
Thanks for any forthcoming help
George
George
