scale
daikin
miflora
presence detection..
the projects above are wonderful python project of members of this forum.
But very difficult to setup: everything in shell, you need writes,drivers, sh scripts, crontabs lots of prerequisites etc.
How difficult is this to (re)write it into the new framework?
and is this possible iwith all the prerequisites?
Plugin request / questions
- Dnpwwo
Re: Plugin request / questions
@remb0,
That's a fair question. It really depends on a few things:
If people are interested in moving something they already have I would suggest they create a new topic in this form and post what they have so that people who have played with the framework already can provide some feedback
- How well the existing projects align to the framework design & constraints
- The services and features it needs to operate
- It is designed to map a single instance of a plugin to a single piece of external hardware that can be connected using either a Serial Port or TCP/IP. If you have more than one instance of the hardware, multiple instances of the same plugin can run.
- A single plugin can map that external hardware to as many internal Domoticz 'devices' as it likes (up to 255 actually)
- The framework should handle the connectivity and messages between Domoticz and the external hardware
blauwebuis
- Domoticz version: current
@remb0
It might be a better idea to have other software that bridges those devices to MQTT. Then they can work with any home automation that supports MQTT. Standards FTW!
An example is the recently developed script that bridges RFLink to MQTT.
https://github.com/Phileep/rflink-to-mqtt
So in this case it might be good to have a Python-to-MQTT library, instead of a Python-to-domoticz plugin construction?
I did a quick search, and found a MiFlora-to-MQTT script for example:
https://github.com/marcelrv/miflora
