Feed back Loop issue
Posted: Tuesday 31 January 2017 13:37
I have following setup
LIghtwaverf Dimmer switch . This is controlled via a Lightwaverf wifilink. This is receive only switch and does not report it's status. So when the switch is controlled manually, Domoticz loses the lights status.
I have installed a light sensor so I can confirm the status of light. It will change the status of the switch in Domoticz from the status of the light sensor and correct the status of the light . This is OK as long as the light sensor is working correctly !!.
Is there any way I can change the status of the switch in Domoticz without actually turning the light on or off , Which will get me out of a false feed back loop and allow me to turn my lights on without Domoticz turning them off again !
