Nefit Easy Pressure stays 25.5bar
Posted: Monday 30 January 2017 16:11
by eurydice
Nefit Easy server v3.1.0
Domoticz v3,5877
System is based upon Windows Server 2012
The pressure of the central heating says and stays on 25.5bar. I cannot fix this, or don't know how.
Regards,
Yves
Re: Nefit Easy Pressure stays 25.5bar
Posted: Monday 30 January 2017 19:30
by SweetPants
You can't fix this because your boiler does not support it. This is normal if not supported
Try:
easy pressure
{"pressure":25.5,"unit":"bar"}
Posted: Tuesday 31 January 2017 8:13
by eurydice
SweetPants wrote:
Try:
easy pressure
Where? in command?
Posted: Tuesday 31 January 2017 8:32
by SweetPants
eurydice wrote:Where? in command?
If you have installed the complete easy set (incl nefit-easy-cli), you should be able to give this CLI command "easy pressure". If it shows 25.5, you boiler (like mine) does not support pressure.
Posted: Tuesday 31 January 2017 10:00
by eurydice
I actually don't know if I have the cli, it worked yesterday I think... but cannot get it to work today..
Posted: Tuesday 31 January 2017 18:53
by SweetPants
eurydice wrote:I actually don't know if I have the cli, it worked yesterday I think... but cannot get it to work today..
What boiler do you have?
https://github.com/robertklep/nefit-eas ... t/issues/6
http://nefit-nl.resource.bosch.com/medi ... tellen.pdf
Posted: Wednesday 01 February 2017 8:01
by eurydice
Not supported for pressure readings... Maybe should've checked that earlier...
