My DomoBox
SystemLord
Domoticz version: Stable
My DomoBox
Post by SystemLord »
Time to share and maybe inspire what to do with a broken Motorola AccessPoint.
Removed the orginal hardware
Slightly adjusted the inside with a dremel tool.
Case provides more than enough natural cooling.
Items in the build:
- Cubietruck Board with SSD beneath
- RazBerry ZWAVE V2
- RFLINK (Arduino Mega) with custom antenna
- Mysensors Gateway
- Running Domoticz :D
Best of all, WAF is high (at least in my case.) Can hang it in the living room as long as no leds are blinking.... :D :roll:
pvm
Domoticz version: 4.10538
Re: My DomoBox
Post by pvm »
Very nice build!
jeroenvanpelt
Domoticz version: 3.8153
Re: My DomoBox
Post by jeroenvanpelt »
Nice job!
Sent from my Nexus 6P using Tapatalk
Domoticz latest stable - RaspberryPi 2 B - MySensors - Controlicz - Google Home - RFLink (w/MiLight)
Mediacj
Re: My DomoBox
Post by Mediacj »
Really nice build!
Thanks for sharing!
gohan
Re: My DomoBox
Post by gohan »
Nice build. Do you mind if I ask why you used the zwave me instead of the USB stick?
SystemLord
Re: My DomoBox
gohan wrote:Nice build. Do you mind if I ask why you used the zwave me instead of the USB stick?
Thx!
I had no specific reason for the zwave other than i had laying around one for a while used on a RPI.
But, if i had the choice:
For advantages, the stick can be carried to a device to include, but personally i managed to include my zwave devices from the front garden to the back garden without any problem using zwave controller on a fixed place in my home. And i believe (not sure) that the razberry zwave is more mature in terms of supporting open zwave. Last, the latest version of the stick has an annoying flashing led that i find disturbing.
sincze
Domoticz version: 2024.4
Re: My DomoBox
Post by sincze »
Very nice indeed, and it just so happens ... I have the same HW :D
Now let's look for a motorola... donor.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
SystemLord
Re: My DomoBox
sincze wrote: Now let's look for a motorola... donor.
Think i can some more of those boxes , send a Pm if intrested.
sincze
Re: RE: Re: My DomoBox
Post by sincze »
Image on its way Image
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Mooseknuckle
Re: My DomoBox
Post by Mooseknuckle »
A big thanks to Systemlord. I just made mine:
Just a Rpi3, Milight controller, Rfxcom and a mysensors gateway. All fixed with some glue:
Hanging on the wall:
More than enough room in the case.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
SystemLord
Re: My DomoBox
Ok, you're quick! :-)
remb0
Re: My DomoBox
Post by remb0 »
very nice! thanks for sharing..
