Using Qubino DIN dimmer ZMNHSD1 as a switch ?
Posted: Sunday 29 January 2017 14:58
by lec668
My setup :
Hardware: Raspberry Pi 3 Model B
OS: OSMC Jessie
Domoticz branch: beta
Version: 3.6555 / Build Hash: 31f858d
I successfully integrated two DIM dimmers in Domoticz.
I tried changing the parameter 5 from dimmerto switch mode, to no avail.
As per Qubino documentation, I have to chage the parameter, exclude the module, then include it again.
Doesn't work. Module stays in dimmer mode always, and is discovered as such.
Any luck using the module as a plain switch ?
Re: Using Qubino DIN dimmer ZMNHSD1 as a switch ?
Posted: Monday 07 August 2017 10:57
by Mat2Vence
I am interested on adding such module in my setup. Did you finally to make it work un On/Off mode?
