I try to follow the instruction on https://www.domoticz.com/wiki/Extractin ... s_with_PHP
I created a php file in domoticz/scripts called extract.php.
When i try to execute in putty with ./extract.php i get the result "Permission denied".
My final goal is to export my data to a mysql database and (try to implement LUA Pass2php from Egregius), but the first step is that php is working.
Somebody a suggestion what i am doing wrong?
PHP: Functions to control Domoticz
Amsterdam020
- Domoticz version: 3.5629
Rp3, youlesss, rfxcom, philips hue, dsb1820
- Egregius
- Domoticz version: v2024.7
Re: PHP: Functions to control Domoticz
Did you disable authentication for 127.0.0.1 under settings, local networks?
Is the error from bash, php or domoticz?
Amsterdam020
Thanks for your reply Egregius.
1) Under settings, local networks I added "127.0.*,192.168.1.*"
2) The error is in bash, btw.
3) i executed chmod 775 extract.php (in bash)
4) when i execute now:
pi@raspberrypi ~/domoticz/scripts $ ./extract.php
I get the result...
./extract.php: line 1: ?php: No such file or directory
./extract.php: line 2: syntax error near unexpected token `('
./extract.php: line 2: ` $json_string = file_get_contents("http://192.168.1.xx:8080/json.htm?type=devices&rid=73");'
5) Is it required to install special php software (which is not mentioned in https://www.domoticz.com/wiki/Extractin ... s_with_PHP )
file extract.php contains...
<?php
$json_string = file_get_contents("http://192.168.1.xx:8080/json.htm?type=devices$
$parsed_json = json_decode($json_string, true);
$test_link = "/home/pi/domoticz/scripts/test_1.txt";
$test_data = fopen ($test_link, "w+");
fwrite ($test_data, print_R($parsed_json, TRUE));
fclose ($test_data);
I get the result...
<?php
- Egregius
Do you have php7-cli installed?
Amsterdam020
Hi Egregius. Took some time before i got into it.
Yes i have installed php7-cli. When i go to http://192.168.1.85/ the php info page is displayed. This is on port 80
Domoticz is running on port 8080. Do i have to enable php on 8080 as well in order to function (or shoudl i move domoticz to 80)?
- Egregius
You can't use the same port. One port for domoticz and one for the php webserver.
