Eldat Easywave / Nikobus / FAAC Altron questions.
Posted: Thursday 26 January 2017 21:22
by aeisenhuth
:?: Hello my name is Adi, I have been using domoticz for 2 weeks. I have an installation on a Windows system with Windows 10 x64. Everything runs so far stable. I already use Philips HUE. Next week, the Xiaomi Gateway 2 comes with some sensors (Temp, Motion, Door). I have but a big hardware problem of Eldat Easywave. A USB Transciver Eldat RTR09 installed as a COM5 can shut down with Putty or Hyperterminal with the command: TXP, 01, A a shutter, with TXP, 01, B high, with TXP, 01, C stop. Since the hardware is not under hardware to find, I had thought I create a dummy switch and there an LUA script which sends the hyperterminal command: TXP, 01, A to the transciver. However, I do not know about LUA, would there be such a possibility? The Eldat RTR09 has 57600 baud, data 8, stop bits 1, no parity, no flow control. Or someone would have a different idea. I would be very grateful for all tips. I have 15 of these blinds at home, 01, channel1, 15 channel 15 each with A, B, C
Re: Eldat Easywave / Nikobus / FAAC Altron questions.
Posted: Saturday 03 February 2018 17:21
by WimR
Hi Adi,
found this old Tread about Easywave.
I've build a Python plugin for the Eldat transciever.
Still Interested?
Wim
Posted: Monday 05 February 2018 15:02
by aeisenhuth
Hi Wim,
I am very interested. How can I help you?
Posted: Saturday 10 February 2018 20:48
by wetlip
Posted: Monday 12 February 2018 10:15
by aeisenhuth
Hello wetLip, thanks for the tip with the driver integration. Did you already somehow run Eldat in domoticz with a plugin etc.
Posted: Tuesday 13 February 2018 10:37
by aeisenhuth
So for the Eldat USB stick would be enough if I enter your code in the command line?
§ sudo modprobe cp210x
§ sudo sh -c 'echo 155a 100D > /sys/bus/usb-serial/drivers/cp210x/new_id'
§ sudo sh -c 'echo 155a 1013 > /sys/bus/usb-serial/drivers/cp210x/new_id'
§ sudo sh -c 'echo 155a 1006 > /sys/bus/usb-serial/drivers/cp210x/new_id'
Remains the driver after a restart.
Here I have obtained an extract of the file cp210x.c from the manufacturer, suitable for the ELDAT RTR09 or the RX09. Line 3 and 4 with Eldat.
Modem */
{ USB_DEVICE(0x13AD, 0x9999) }, /* Baltech card reader */
{ USB_DEVICE(0x155A, 0x1005) }, /* ELDAT Easywave Transceiver */
{ USB_DEVICE(0x155A, 0x1006) }, /* ELDAT USB Transceiver Easywave
Posted: Wednesday 14 February 2018 16:36
by aeisenhuth
So Eldat RTR09 is now installed in PI3. Here a small wiki:
1. Create a text file in /etc/modules-load.d. Name cp210x.conf with the following content: cp210x
2. Open the file domoticz.sh in /etc/init.d.
3. At line 95 --> ["$ Verbose"! = No] && log_daemon_msg "Starting $ DESC" "$ NAME"
add the following in a new line:
#Parameters for the kernel module cp210x
echo "parameter for kernel module cp210x set .."
sh -c 'echo 155a 1005 > /sys/bus/usb-serial/drivers/cp210x/new_id'
It works for me fine, now the Eldat Transciver Stick is working
Now I just have to watch as I create a command via Python so that it addresses the blinds.
Thanks wetlip
