LightwaveRF socket - lock/unlock commands
Posted: Wednesday 25 January 2017 23:11
Ive setup some LightwaveRF sockets (JSJS LW270) with RFXtrx433, the on/off is working fine.
Does anyone know how to send a lock/unlock command to these sockets? so the physical switch can not be used.
I have bought a Socket Locker remote and have paired it with a socket and it does lock/unlock fine.
How can i do this through Domoticz without the remote?
I tried to duplicate the remote on Domoticz but am having no luck. If i learn the remote, i can see the status changing when i press the buttons, ie lock/unlock/all lock/on/off. However i can only send on/off commands via Domoticz.
Any Ideas????
This is what RFXmngr is receiving
Packettype = Lighting5
subtype = LightwaveRF
Sequence nbr = 0
ID = 008E8F decimal:36495
Unit = 1
Command = Lock
Signal level = 7 -64dBm
Sequence nbr = 1
Unit = 1
Command = All lock
Sequence nbr = 2
Unit = 1
Command = On
Sequence nbr = 3
Unit = 1
Command = Off
Any Ideas????
Sequence nbr = 0
Unit = 1
Command = Lock
Sequence nbr = 1
Unit = 1
Command = All lock
Sequence nbr = 2
Unit = 1
Command = On
Sequence nbr = 3
Unit = 1
Command = Off
