Lua triggerd very often
Posted: Wednesday 25 January 2017 16:52
Hi there,
i have wrote a LUA scripte. You can see this below.
My Problem is the Script is triggerd very often. The Temperature isn't changed in this time. The Setpoint devices is the same Danfoss LC-13
I have attached the log below two.
Why is it triggerd so often.
LOG FIle:
local act_time = os.date("%H:%M")
if ((otherdevices['Esszimmer Heizung']~='16') or (otherdevices['Wohnzimmer Heizung 1']~='16')) and (otherdevices['Wohnzimmer Heizung']=='17°C') then
commandArray[1]={['UpdateDevice']="48|0|16"}
commandArray[2]={['UpdateDevice']="50|0|16"}
print("Heizung auf 16°C eingestellt")
elseif ((otherdevices['Esszimmer Heizung']~='23') or (otherdevices['Wohnzimmer Heizung 1']~='23')) and (otherdevices['Wohnzimmer Heizung']=='23°C') then
print(otherdevices['Wohnzimmer Heizung 1'])
print(otherdevices['Esszimmer Heizung'])
commandArray[1]={['UpdateDevice']='50|0|23'}
commandArray[2]={['UpdateDevice']='48|0|23'}
commandArray[3]={['Variable:Heizungschalten']=act_time}
print("Heizung auf 23°C eingestellt")
return commandArrayCode: Select all
2017-01-25 16:38:42.288 User: Tim initiated a switch command (22/Anwesenheit/Off)
2017-01-25 16:43:09.549 LUA: 23
2017-01-25 16:43:09.549 LUA: 23.00
2017-01-25 16:43:09.549 LUA: Heizung auf 23°C eingestellt
2017-01-25 16:43:09.553 EventSystem: Script event triggered: Heizungneu
2017-01-25 16:43:09.739 LUA: 23
2017-01-25 16:43:09.739 LUA: 23.00
2017-01-25 16:43:09.739 LUA: Heizung auf 23°C eingestellt
2017-01-25 16:43:09.744 EventSystem: Script event triggered: Heizungneu
2017-01-25 16:43:15.778 LUA: 23.00
2017-01-25 16:43:15.779 LUA: 23
2017-01-25 16:43:15.779 LUA: Heizung auf 23°C eingestellt
2017-01-25 16:43:15.784 EventSystem: Script event triggered: Heizungneu
2017-01-25 16:43:15.979 LUA: 23.00
2017-01-25 16:43:15.979 LUA: Heizung auf 23°C eingestellt
2017-01-25 16:43:15.984 EventSystem: Script event triggered: Heizungneu
2017-01-25 16:43:50.799 EventSystem: reset all events...
2017-01-25 16:48:12.131 LUA: 23.00
2017-01-25 16:48:12.132 LUA: Heizung auf 23°C eingestellt
2017-01-25 16:48:12.135 EventSystem: Script event triggered: Heizungneu
2017-01-25 16:48:12.322 LUA: 23.00
2017-01-25 16:48:12.322 LUA: Heizung auf 23°C eingestellt
2017-01-25 16:48:12.327 EventSystem: Script event triggered: Heizungneu
