Install script failing
Posted: Tuesday 24 January 2017 10:08
When attempting to install on Lubuntu 16.10 while executing this:
sudo curl -L install.domoticz.com | bash
This happens:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 16225 0 16225 0 0 40912 0 --:--:-- --:--:-- --:--:-- 40869
::: Script called with non-root privileges. The Domoticz installs server packages and configures
::: system networking, it requires elevated rights. Please check the contents of the script for
::: any concerns with this requirement. Please be sure to download this script from a trusted source.
::: Detecting the presence of the sudo utility for continuation of this install...
::: Utility sudo located.
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Downloading Domoticz
::: Current User: jensc
HTTP Port: 8080
HTTPS Port: 443
::: Destination folder=/home/jensc/domoticz
--2017-01-24 01:00:16-- http://www.domoticz.com/download.php?ch ... chine=i686
Resolving http://www.domoticz.com (http://www.domoticz.com)... 104.31.79.142, 104.31.78.142
Connecting to http://www.domoticz.com (http://www.domoticz.com)|104.31.79.142|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://releases.domoticz.com/releases/r ... x_i686.tgz [following]
--2017-01-24 01:00:16-- http://releases.domoticz.com/releases/r ... x_i686.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 104.31.78.142, 104.31.79.142
Reusing existing connection to http://www.domoticz.com:80.
HTTP request sent, awaiting response... 404 Not Found
2017-01-24 01:00:17 ERROR 404: Not Found.
This happens:
::: You are root.
HTTP Port: 8080
HTTPS Port: 443
