Missing devices with FIBARO System FGD212 Dimmer 2
Posted: Monday 23 January 2017 14:16
by Duggel
Last week I've added an second Fibaro dimmer type 2 to my zwave network.
Inclusion was no problem, but only 3 new devices show up in the devices list.
2 times usage and 1 kwh meter (see attached screenshot).
The light itself is not visible as device, so I can't controll the light via Domoticz.
I allready tried removing and adding it again, but still only 3 devices show up.
Is the Fibaro dimmer broke, or am I doing something wrong?
- Schermafbeelding 2017-01-23 om 14.02.04.png (26.75 KiB) Viewed 1857 times
Re: Missing devices with FIBARO System FGD212 Dimmer 2
Posted: Sunday 29 January 2017 8:57
by tontze
Did you try to reset it before adding again ?
Posted: Sunday 29 January 2017 9:33
by nizaga
question: how many device should show up after adding the FGD212 in total?
or even more general, is there a way to indentify how many domoticz devices should be created after including a zwave device based on the config.xml file?
I have just added for instance a FGD212, reading the fgd212.xml should i be able to get this information? if not, where is the logic to add devices for a specific zwave device?
Thanks,
nim
Posted: Sunday 29 January 2017 9:56
by Gravityz
you need to give it more time.
you need a couple of watt devices, kwh devices, lightswitch and scene devices
sometimes you get more than one device which does the same so you have to look which one is active/will react
include the device and make sure you have allow new devices set to on in setup.
after the module is recognized start switching (push switch 1, switch 2)
this will probably generate the devices
with s2 you can generate devices for 1 click, 2 clicks, 3 clicks, click and hold, release.
Posted: Sunday 29 January 2017 22:21
by nizaga
With s2, you connect a cable from another wall switch then?
Enviado desde mi iPhone utilizando Tapatalk Pro
Posted: Monday 30 January 2017 8:38
by Gravityz
no you connect it to a second switch ne3xt to the first one
something like this
https://nl.dreamstime.com/stock-foto-du ... ge65396668
first switch is S1 which controls the dimming
S2 is the second one which you can program to do anything.
Posted: Monday 30 January 2017 13:34
by Duggel
tontze wrote:Did you try to reset it before adding again ?
Resetting it did the trick. After resetting and including it, 21 new devices showed up
Posted: Monday 30 January 2017 18:40
by Gravityz
now you have to check what they do.
also your screenshot shows 2 devices(D and E)
if you have one device then D is probably the old device which does not work anymore so E are the active ones
