Vision ZD2102EU GEN3 issue
Tamagnun
Post by Tamagnun »
Hi everybody, I ordered nine Vision ZD2102 GEN5 door/window sensors, but the seller sent me four x GEN5 and five older GEN3 items.
All works well with the GEN5 items, but the GEN3 works at 50%. After inclusion:
xxxx00    Sensor            works properly (goes ON/OFF dependency by the magnet posistion, good!)
0xxxx     Alarm Type 0x07   the same as SENSOR
xxxx32    Alarm Level       the same as SENSOR
xxxx33    Alarm Type        always set to ON, updated on log every time the internal tamper OR the magnet                                            switch change state
xxxx35    Burglar           the same as ALARM TYPE
In other words, the tamper function (BURGLAR) cannot be monitored with this node version.
In addition (minor problem) it is recognized as Vision ZD2102 AU Door/Window Sensor despite it works on European frequency, official Vision documentation returns that its identifiers (id=0x0102 model=0x2001) are referred to Indian version!! :?: :?:
The behaviour is the same even if included in a network based on a GEN3 or GEN5 controller, both including the node as SECURE or NOT SECURE.
Is somebody using this node version? Same wrong behaviour or not?
Domoticz version is 3.5877 (last stable), OpenZWave Version: 1.4-2228-gbce4a88-dirty
Tamagnun
Re: Vision ZD2102EU GEN3 issue
Post by Tamagnun »
Anyone is using this D/W sensor?
Any experience about it?
