Hue white instead of RGBW
Posted: Saturday 21 January 2017 19:09
Dear Domoticz users, after almost 3 years of happy usage i'm running into some problems with my current setup.
Momentarily I have around 25 Hue lamps. Some are ''on their own'' and others are part of a lamp or group.
In some cases a group consists of only Hue white bulbs. Unfortunatelly when adding the group/room to Domoticz I'm running into the following issue. The group is automatically seen asLightning, Limitless/Applamp with the SubType: RGBW
When trying to switch the lamps/group/room via Domoticz the following pop-up appears
This isn't needed since there are only white bulbs available (no color temp, just dim)
I'm looking for an option to use the lamps/group/room the same as the dimmer below. So just on/off and a slider
Currently the lamps/group/room have the following settings
(setting the lamp to the white option next to the colorpicker is just to change the current color value not the switch type itself)
Is there a way to change the type of the device so that domoticz will tread it as a regular dimmer instead of RGBW values?
Your help is very much appreciated!!!
