Domoboard - Feature requests
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
This topic is used to discuss feature requests.In order to fix issues or add features these have to be reported on one of the the Domoboard Github pages:
https://github.com/wez3/domoboard
https://github.com/wez3/domoboard-plugins
wez3
wez3
Re: Domoboard - Feature requests
Is it possible to get local raindata from buienradar and put the information in a bar graphic?
In this way we can see for the next half an hour if it is going to rain. (Subdivided by 5 minutes)
Here is a topic about a Python script.
http://www.domoticz.com/forum/viewtopic.php?t=13938
Maybe create a default template with an embedded YouTube video to show the possibilities of Domoboard.
The video-URL itself preferrably defined in the *.conf file.
Something like viewtopic.php?f=66&t=15128&p=114888&hil ... be#p114888.
Txs.
Txs.
- Domoticz version: 3.5837
Jep we already did but for iframes. With the block plugin you can give an src URL and the plugin shows this as an template in domoboard
But for YouTube it could be the same if we copy the block plugin and change the template to import an YouTube src
Would like to skip the login screen. Only users on my netwerk can access the page.
Alternatively do not require login each time on an iPad.
hmm i will look into that, i maybe found an solution for this without stripping the secure api requests.GuyTreepbush wrote:Would like to skip the login screen. Only users on my netwerk can access the page.
Just created an feature to add autologon functionality to domoboard.
If you get the latest develop update you can add autologon to the domoboard section in general settings and add True or False like this:
[[domoboard]]
time = False # True/False: show time in top bar
date = False # True/False: show date in top bar
autologon = False # True/False: enable autologon
I tried this with the block plugin and you know what, it actually works instantAwst6000 wrote:Hi,
Txs.
for example:
[[block]]
src = https://www.youtube.com/embed/watch?v=lAsXqfzRiWQ
Great!
I think it is wise to add this to the default example.conf.
This weekend I'll try to get a default YouTube-playlist in Domoboard.
Is it possible to change the background color of the dashboard?
Or to have a picture as background?
Re: Domoboard - Feature requests - Thermostat button
Now the thermostat is a slider in Domoboard. I want to have a + and - button. Is that possible?
Because a slider is not accurate enough to operate with touch.
I don't know how can I make this. Can someone help me?
thanks!
thanks!
I think if you change the setpoint_slider to setpoint it should work and you will get en up and down option.
