Python Plugin: import Module
Posted: Friday 20 January 2017 1:17
by zaraki673
I want to create a new plugin who use
bluepy to check and control Awox Smartplug
I already write a
python script for domoticz who read status from the plug and send data to domoticz.
My domoticz system is a rpi3 with raspbian jessie lite and I compile domoticz from source (Version: 3.6389), PluginSystem work very well (I tried with Kody plugins, all work fine)
But with my new plugin, when i ask to import bluepy it's fail with this error :
2017-01-19 23:59:03.109 Error: (smp) Module Import failed, exception: 'ImportError'
2017-01-19 23:59:03.109 Error: (smp) Module Import failed: ' Name: bluepy'
My code work for configuration in Hardware menu and create news devices, but don't load bluepy module
here the beginning of my plugin :
- Spoiler: show
# Awox SmartPlug Plugin
# Author: zaraki673, 2017
<plugin key="AwoxSMP" name="Awox SmartPlug" author="zaraki673" version="1.0.0">
<params>
<param field="Mode1" label="MAC Address" width="150px" required="true"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import binascii
import struct
from bluepy import btle
START_OF_MESSAGE = b'\x0f'
END_OF_MESSAGE = b'\xff\xff'
SMPstate = 0
SMPconso = 0
# Domoticz call back functions
def onStart():
global SMPstate, SMPconso
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
if (len(Devices) == 0):
Domoticz.Device(Name="Status", Unit=1, TypeName="Switch").Create()
Domoticz.Device(Name="Conso", Unit=2, TypeName="Usage").Create()
Domoticz.Log("Devices created.")
else:
if (1 in Devices): SMPstate = Devices[1].nValue
if (2 in Devices): SMPconso = Devices[2].nValue
DumpConfigToLog()
Domoticz.Heartbeat(5)
return True
def onConnect(Status, Description):
return True
def onMessage(Data, Status, Extra):
return True
def onCommand(Unit, Command, Level, Hue):
return True
def onNotification(Data):
Domoticz.Log("Notification: " + str(Data))
return
def onHeartbeat():
try:
(state, power) = plug.status_request()
except btle.BTLEException as err:
Domoticz.Log('error when requesting stat to plug %s (code %d)' % (args.ble_addr, err.code))
# print result
status = 'on' if state else 'off'
Domoticz.Log('plug state = %s' % status)
SMPstate = status
Domoticz.Log('plug power = %d W' % power)
SMPconso = power
return True
def onDisconnect():
return True
def onStop():
return True
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
How does Python Framework work in Domoticz ?
I try in command line to import the module, it's work ...
thank's for your help
Re: Python Plugin: import Module
Posted: Friday 20 January 2017 4:44
by Dnpwwo
@zaraki673,
I had a look at the script and it looks okay (I'm not a Python expert even though I wrote the framework) and as you have said it is complaining about the bluepy import which implies that it has found and loaded the plugin itself.
There should be another message right above the 2 errors you posted that shows the Python path that will be searched for imports, if you have that can you confirm that the bluepy library is in one of those folders or in the same folder as the plugin?
Posted: Friday 20 January 2017 5:38
by zaraki673
you're right
install bluepy in /usr/local/lib/python3.4/dist-packages/bluepy/
but python framework search in /usr/lib/python3.4/
i just do
sudo cp -r /usr/local/lib/python3.4/dist-packages/bluepy/ /usr/lib/python3.4/
and now it's load
thank's
Posted: Thursday 02 February 2017 10:45
by deennoo
@Dnpwwo
Did you plan to introduce a dependency installer, or a install script to automatise installation of some dependency ?
I have idea to make a plugin for Yeelight Bt Bedside lamp, found a python Lib for it but need to be installed :
https://github.com/rytilahti/python-yeelightbt and it use bluepy and bluez.
Posted: Thursday 02 February 2017 12:47
by Dnpwwo
@deenoo,
I wasn't planning on doing this because it shouldn't be required.
I haven't done it but my understanding is that if you put the import target in the same directory as the plugin (or anywhere in the Python Path) it should be found. This is standard Python functionality and not something I have done.
Can you try it and report back?
