If device is on for 5 minutes
stingone
Post by stingone »
Hi everyone,
Is there any possibily to write a rule that uses the (if device is on for 5 minutes then?) could not find it with blockly.
Egregius
Domoticz version: v2024.7
Re: If device is on for 5 minutes
Post by Egregius »
Probably not in blockly, but in pass2php very simple:
if($sdevice=='On'&&$tdevice<time-300){
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
@Egregius:
Yes you are brilliant!
And in pass2php everything is possible,.... as you answer to each question.
But this is the Blockly section, PHP has his own section, and keep it there!
My wife and children don't understand PHP, but can edit and maintain Blockly.
Maintaining domotica is more important than creating domotica.
Rather important: even you will die one day.
@stingone
Use a dummy device (DUMDEV) to remember the state of your device DEV
Something like this (not tested)
IF DEV=ON and DUMDEV=ON
SET DUMDEV OFF after 300 seconds
IF DEV=ON and DUMDEV=OFF
SET "do your thing"
IF DEV=OFF and DUMDEV=OFF
SET DUMDEV=ON
(remember: ELSE is not a real ELSE ... all branches are checked always
Hope this helps
Egregius
Post by Egregius »
Oh, because we're not in the PHP board one may not suggest PHP?
