Send {"status" : "OK"} response on HTTP request
Posted: Tuesday 17 January 2017 19:23
Hello everybody,
I have a problem to understand how to send response to when Domoticz send order to my ESP8266.
Wiki is not very precise about this point and i need more details : https://www.domoticz.com/wiki/Domoticz_ ... s#Response
Situation :
I have installed an ESP12F in my bathroom's radiator. Firmware is entirely custom and written with Arduino IDE. All is working pretty well : I can control On/Off with a local switch (that send update state to Domoticz), control On/Off remotely with Domoticz, and send temperature value to Domoticz.
My problem is when Domoticz send On or Off command to my module, few second later i have an error "Error: Error opening url: http://***.***.***.***/On" on Domoticz log. I think there is a problem of response. My module must send response {"status" : "OK"} but i don't know how and in which format.
My code to receive Domoticz command (in which i want to include response function) :
My code to send temperature and humidity data :
My code to send state On or Off when switched locally :
I don't know if i should use function like the 2 last, with HTTP/1.1 and other elements, or other form. I have tried lot of things but can't send response to Domoticz, and always have error "Error opening url: http://***.***.***.***/On" in Domoticz's log.
Thanks for your help and explanation
, i really want to understand this point.
Situation :
WiFiClient client = server.available();
if (client) {
String req = client.readStringUntil('\r'); // Read the first line of the request
if (req.indexOf("On") >=0) { // If "On" is send by Domoticz in request, activate Pin_relay
digitalWrite(Pin_relay, LOW);
statut_radiateur = 1;
if (req.indexOf("Off") >=0) { // If "Off" is send by Domoticz in request, desactivate Pin_relay
digitalWrite(Pin_relay, HIGH);
statut_radiateur = 0;
client.flush();
}Code: Select all
if (client.connect(domoticz_server,port)) {
client.print("GET /json.htm?type=command¶m=udevice&idx=5");
client.print("&nvalue=0&svalue=");
client.print(String(temperature));
client.print(";");
client.print(String(humidity));
client.print(";0");
client.println(" HTTP/1.1");
client.print("Host: ");
client.print(domoticz_server);
client.print(":");
client.println(port);
client.println("User-Agent: Arduino-ethernet");
client.println("Connection: close");
client.println();
client.stop();
client.print("GET /json.htm?type=command¶m=udevice&idx=3");
client.print("&nvalue=1");
client.print(":");
client.println();
client.stop();
}Thanks for your help and explanation
