FIBARO FGK101 visible but not working IRL
Posted: Sunday 15 January 2017 14:32
On my Domoticz v3.5877 system I have several FIBARO System FGK101 sensors. One of them quit working on the 26st of December, so Domoticz thinks. I did an exclude and later include of the FGK101 sensor, the device appears in the list. Also, the blue LED is flashing when I insert the battery in the device.
What is NOT working -and I hope anyone can help me- is: when I normally make or brake the contact, the LED flashes and the device signals to Domoticz. None of those two things happen with this device. I used the device with another magnet, no luck.
So the strange is: the battery must be OK, because including and excluding the device work! Only the main functions of the device (making and braking) don't work! Like in this picture, the LED works (blue). In my case, nothing happens when I make or brake the contact.
Ps. I already did a reset with the procedure described at http://manuals.fibaro.com/door-window-sensor/ .
