problems with re-install and update
Posted: Saturday 14 January 2017 19:47
After some problems i decided to reinstall domoticz.
I am running version 2.3530 now.
Under setup-> more options-events however the option to choose between blockly or lua disappeared so I cannot enter a lua script .
Besides that when I check for updates I get the message 'No updates avalilable.
After that I tried an install of the latest stable version. When putting back domoticz.db and starting domoticz I get the message that there are no devices and I first have to install hardware first.
when I enter sudo curl -L install.domoticz,com |sudo bash nothing happens. Only the message that I should run apt-get upgrade after insatlling Domoticz
No new version is installed.
I probably miss a step somewhere. Should I give some command to install the new version ?
Pleez help me out on this because I don't like to begin from scratch.
Thanks in advance
Thanks in advance
