[script] PIco UPS HV3.0A [get output] Pico_Status.py (0x18)
Posted: Saturday 14 January 2017 13:30
by Siewert308SW
Just wanna put this script here.
It aint got nothing to do with Domoticz but for those on a RPi with a UPS PIco HV3.0A series it may come in handy.
Posted on PiModules also but maybe some of the users here can have the benefit of this script.
Took the old v1.0 which isn't compatible with the PIco HV3.0A series.
Grabbed some extra stuff and added new register stuff.
And updated the existing registers to correspond our PIco UPS HV3.0A series.
Be aware:
The info output depends on registers,
So if a register isn't right in the script or not corresponding your board then the output could be false.
Or i made a mistake as this is my first python (the script language) script.
Amend the script if necessary to suite your corresponding register values for your board.
Script:
#!/usr/bin/python
# pico_status.py
# author : Kyriakos Naziris
# updated: 1-12-2017
# Script to show you some statistics pulled from your UPS PIco HV3.0A
# -*- coding: utf-8 -*-
# improved and completed by PiModules Version 1.0 29.08.2015
# picoStatus-v3.py by KTB is based on upisStatus.py by Kyriakos Naziris
# Kyriakos Naziris / University of Portsmouth / [email protected]
# As per 09-01-2017 improved and modified for PiModules PIco HV3.0A Stack Plus / Plus / Top by Siewert Lameijer
# You can install psutil using: sudo pip install psutil
#import psutil
# SETTINGS
# Set your desired temperature symbol
# C = Celsius
# F = Fahrenheit
degrees = "C or F"
# It's not necessary to edit anything below this line unless your knowing what to do!
import smbus
import time
import datetime
i2c = smbus.SMBus(1)
def fw_version():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x69, 0x26)
   data = format(data,"02x")
   return data
def boot_version():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x69, 0x25)
   return data
def pcb_version():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x69, 0x24)
   return data
def pwr_mode():
   data = i2c.read_byte_data(0x69, 0x00)
   data = data & ~(1 << 7)
   if (data == 1):
      return "RPi POWERED"
   elif (data == 2):
      return "BAT POWERED"
   else:
      return "ERROR"
def charger_state():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x69, 0x20)
   if (data == 0):
      return "DISCHARGING"
   if (data == 1):
      return "NOT CHARGING"
   elif (data == 2):
      return "CHARGING"
   else:
      return "ERROR"
def bat_version():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x6b, 0x07)
   if (data == 0x46):
      return "LiFePO4 (ASCII : F)"
   elif (data == 0x51):
      return "LiFePO4 (ASCII : Q)"
   elif (data == 0x53):
      return "LiPO (ASCII: S)"
   elif (data == 0x50):
      return "LiPO (ASCII: P)"
   else:
      return "ERROR"
def bat_runtime():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x6b, 0x01) + 1
   if (data == 0x100):
      return "TIMER DISABLED"
   elif (data == 0xff):
   else:
      data = str(data)+ " MIN"
      return data
def bat_level():
   time.sleep(0.1)
   data = i2c.read_word_data(0x69, 0x08)
   return (float(data) / 100)
def bat_percentage():
   time.sleep(0.1)
   datavolts = bat_level()
   databattery = bat_version()
   if (databattery == "LiFePO4 (ASCII : F)") or (databattery == "LiFePO4 (ASCII : Q)"):
		datapercentage = ((datavolts-2.9)/1.25)*100
   elif (databattery == "LiPO (ASCII: S)") or (databattery == "LiPO (ASCII: P)"):
		datapercentage = ((datavolts-3.4)/0.75)*100
   return datapercentage
def rpi_level():
   time.sleep(0.1)
   data = i2c.read_word_data(0x69, 0x0a)
def ntc1_temp():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x69, 0x1b)
   if (degrees == "C"):
	return data
   elif (degrees == "F"):
	return (float(data) * 9 / 5) + 32
def to92_temp():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x69, 0x1C)
	return data
def epr_read():
   time.sleep(0.1)
   data = i2c.read_word_data(0x69, 0x0c)
def ad2_read():
   time.sleep(0.1)
   data = i2c.read_word_data(0x69, 0x07)
def fan_mode():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x6b, 0x11)
   data = data & ~(1 << 2)
   if (data == 1):
      return "ENABLED"
   elif (data == 0):
      return "DISABLED"
   else:
      return "ERROR"
def fan_state():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x6b, 0x13)
   if (data == 1):
      return "ON"
   elif (data == 0):
      return "OFF"
   else:
      return "ERROR"
def fan_speed():
   time.sleep(0.1)
   data = i2c.read_word_data(0x6b, 0x12)
   return (float(data) * 10)
def r232_state():
   time.sleep(0.1)
   data = i2c.read_byte_data(0x6b, 0x02)
   if (data == 0x00):
      return "OFF"
   elif (data == 0x01):
      return "ON @ 4800 pbs"
   elif (data == 0x02):
      return "ON @ 9600 pbs"
   elif (data == 0x03):
      return "ON @ 19200 pbs"
   elif (data == 0x04):
      return "ON @ 34600 pbs"
   elif (data == 0x05):
      return "ON @ 57600 pbs"
   elif (data == 0x0f):
      return "ON @ 115200 pbs"
   else:
      return "ERROR"
print " "
print "***********************************"
print "      UPS PIco HV3.0A Status       "
print " "
print " ","UPS PIco Firmware.....:",fw_version()
print " ","UPS PIco Bootloader...:",boot_version()
print " ","UPS PIco PCB Version..:",pcb_version()
print " ","UPS PIco BAT Version..:",bat_version()
print " ","UPS PIco BAT Runtime..:",bat_runtime()
print " ","UPS PIco r232 State...:",r232_state()
print " "
print " ","Powering Mode.........:",pwr_mode()
#print " ","Charger State.........:",charger_state()
print " ","BAT Percentage........:",bat_percentage(),"%"
print " ","BAT Voltage...........:",bat_level(),"V"
print " ","RPi Voltage...........:",rpi_level(),"V"
	print " ","NTC1 Temperature......:",ntc1_temp(),"C"
	print " ","TO-92 Temperature.....:",to92_temp(),"C"
	print " ","NTC1 Temperature......:",ntc1_temp(),"F"
	print " ","TO-92 Temperature.....:",to92_temp(),"F"
else:
	print " ","NTC1 Temperature......: please set your desired temperature symbol!"
	print " ","TO-92 Temperature.....: please set your desired temperature symbol!"
print " ","Extended Voltage......:",epr_read(),"V"
print " ","A/D2 Voltage..........:",ad2_read(),"V"
print " "
print " ","PIco FAN Mode.........:",fan_mode()
print " ","PIco FAN State........:",fan_state()
print " ","PIco FAN Speed........:",fan_speed(),"RPM"
print " "
print "         Powered by PiCo			  "
print " "
pico_status.zip
(1.7 KiB) Downloaded 84 times
