[Solved]Python scripting: Get temprature and Hum value
vleud101
Domoticz version: 15b013c
Post by vleud101 »
Dear Domoticz forum people,
I have a PLC connected to my raspberry pi and i can successfully send values to the PLC Datablocks with Python scripting (Snap7).
My final goal is to use the PLC to control the heat in the house with several floorheaters and those are controlled by several valves to control each room.
Now i bought 6 temparature sensors (WH-5) to send from each room trough RFXCOMe the data to domoticz on a RPI.
My problem is that I am not a Python scripting hero, so i hope some can help me with the scripting.
import sys
import datetime
import time
import os
import subprocess
import urllib2
import json
import base64
domoticzserver="192.168.1.xxx:8080"
domoticzusername = "xxxx"
domoticzpassword = "xxxxx"
device = "45"
log_to_file = True
base64string = base64.encodestring('%s:%s' % (domoticzusername, domoticzpassword)).replace('\n', '')
domoticzurl = 'http://'+ domoticzserver +'/json.htm?type=command&param=udevice&idx=' + device +'&nvalue=0&svalue=TEMP;HUM;HUM_STAT'
def log(message):
   print message
   if log_to_file == True:
      logfile = open(sys.argv[0] + '.log', "a")
      logfile.write(message + "\n")
      logfile.close()
def domoticzrequest (url):
  request = urllib2.Request(url)
  request.add_header("Authorization", "Basic %s" % base64string)
  print(request)
  response = urllib2.urlopen(request)
  return response.read()
def domoticzstatus():
   json_object = json.loads(domoticzrequest(domoticzurl))
   getvalue = 0
   # Search the device in JSON list
   if json_object["status"] == "OK":
      getvalue = json_object["result"][0]["Data"]
   else:
      print (datetime.datetime.now().strftime("%H:%M:%S") + "- Error. Could not find device idx in Domoticz response.")
   status = format(float(getvalue[:-1]), '.2f')
   return status
log (datetime.datetime.now().strftime("%H:%M:%S") + "- script started.")
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + device + '&nvalue=0&svalue=TEMP;HUM;HUM_STAT')
Now i know if i run the url at my webbrowser i get:
http://xxxx:[email protected]:8080/js ... M;HUM_STAT
status: "OK",
title: "Update Device"
So i know my password and link is OK (Also IDX).
If i run my python scripts i get as output:
16:03:29- script started.
<urllib2.Request instance at 0x767f1c10>
I want to use the output a variable as float for Temp and seperat for Hum also as float.
So Temp =
and Hum =
So i can use those two variables to send to my PLC.
vleud101
Re: [Help]Python scripting: Get temprature and Hum value
Post by vleud101 »
Update:
Ok I made a mistake by defining the url. Now it works:
#---------------Benodigheden------------------
import sys
import datetime
import time
import os
import subprocess
import urllib2
import json
import base64
#---------------Settings---------------------
domoticzserver="192.168.1.210:8080"
domoticzusername = "xxx"
domoticzpassword = "xxxx"
device = "45"
log_to_file = True
#---------------Variabelen--------------------
degrees = "Test"
temp = 0
humi = 0
hum_stat = 0
#---------------Wachtwoordenzooi--------------
#domoticzurl = 'http://'+ domoticzserver +'/json.htm?type=command&param=udevice&idx=' + device +'&nvalue=0&svalue=TEMP;HUM;HUM_STAT'
domoticzurl = 'http://192.168.1.210:8080/json.htm?type=devices&rid=45'
#---------------Logging-----------------------
def log(message):
   print message
      logfile.close()
#---------------Info ophalen------------------
  print(request)
#--------------Status-------------------------
	temp = json_object["result"][0]['Temp']
# getvalue = json_object['result'][0]['Data']
# temp_stat = json_object["result"][0]["TEMP"]
#	hum_stat = json_object["result"][0]["HUM_STAT"]
#return hum_stat
	# #return getvalue
# #return 0
print(temp)
#log (datetime.datetime.now().strftime("%H:%M:%S") + "- script started.")
#domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + device + #'&nvalue=0&svalue=TEMP;HUM;HUM_STAT')
#print(domoticzrequest)
I hope some people have some use for it. Most of the time there are only examples to get information IN domoticz and not OUT :mrgreen:
