can't get domoticz installed/running
Posted: Friday 13 January 2017 14:23
I tried to install domoticz, but i can't get it to work.
its a ubuntu 12.04LTS i686 system.
first error was when trying:
'sudo curl -L install.domoticz.com | bash'
*sidenote: sudo is not nessesery, because i am logged in as root. however, thats not the problem.
The scripts runs, asks some questions.. and stops. because of a 404 (can't download the package).
Problem was found quick; the ${Mach} var output was i686.. but if i go to the url.. it doesn't support that...
so downloaded the script... changed ${Mach} to x64_i686 and runs the script again (looks like x64_i686 is the only available download if i go to the download page of domoticz).
now setup is running fine... however... nothing is running at 8080 or 443...
Trying to run /etc/init.d/domoticz.sh start gives the following error:
i also tried to compile and install from source.. but looks like that is far above my knowledge how to manage that.
any suggestions what to do next?
can't find anything on the web about this.start-stop-daemon: unable to start /home/root/domoticz/domoticz (Exec format error)
