How to change Domoticz web title? Topic is solved
arkoko
Post by arkoko »
I have multiple Domoticz instances and often they are open into differenet tabs in the browser. It would be great to have customized tabs titles to quick select.
I tried to edit index.html title in the header section:
<title>Domoticz 2</title>
but it does not have effect, even with "-nocache" switch.
Screenshot 2017-01-11 23.24.39.png (2.68 KiB) Viewed 13805 times
Is there any way to do it?
gizmocuz
Re: How to change Domoticz web title?
Post by gizmocuz »
there is probably an chrome extension that can do this
mzonneveld
Post by mzonneveld »
arkoko wrote: Wednesday 11 January 2017 22:41 I have multiple Domoticz instances and often they are open into differenet tabs in the browser. It would be great to have customized tabs titles to quick select.
Put this code somewhere into your index.html
<script>
 setInterval(function(){
    titel = location.href;
    if (titel.indexOf('#') >= 0) {
        titel = titel.split('#')[1];
        titel = titel.split('?')[0];
        titel = titel.replace('/', '') + ' - DZ';
        titel = titel.trim(' ').trim('-');
        document.title = titel;
  }, 500);
</script>
mark.sellwood
Post by mark.sellwood »
Have you tried the following:-
Go to Setup then Settings, on the System tab under the Location enter what ever you want to be displayed in the name field.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
mark.sellwood wrote: Saturday 18 May 2024 22:23 Have you tried the following:-
Indeed, that is the way to go. No need to change the source code for this.
