Get info from homealarm (chuango)
Posted: Tuesday 10 January 2017 13:06
by Ivanhoe1
Checking possiblities to connecta a sensor (like Fibaro Universalsensor) to my home alarm (chuango g5).
I would like to get inputs to domoticz when the alarm is activated/dectivated and when the alarm goes off. Do you think its possible to connect any universalsensor to the outputs (see attached image) to get this info?
Re: Get info from homealarm (chuango)
Posted: Friday 13 January 2017 15:16
by jadon
Chuango uses 433 protocol. I have the same (only branded as Eminent) and I would also like to know how to turn the alarm on/off. But I guess it wouldn't make it very secure if you can switch it off wireless...
Maybe you can use the electronic lock relay for detecting if the alarm is activated/deactivated), but you should check the manual for specs
Posted: Friday 13 January 2017 15:22
by emme
you can intercept the radio communication of each device (433mhz) but you have to note that chiango does NOT send the close signal, just the OPEN (for reed devices)
I had one, and I'm actually migrating to Zwave (well.. the chuango controller exploded due to battery leack
Posted: Sunday 15 January 2017 21:51
by Ivanhoe1
jadon wrote:Chuango uses 433 protocol. I have the same (only branded as Eminent) and I would also like to know how to turn the alarm on/off. But I guess it wouldn't make it very secure if you can switch it off wireless...
Yes and the output for wired siren might work as input to domoticz for triggerd alarm.
