Domoticz & RFlink & temperature sensor
Posted: Tuesday 10 January 2017 9:38
Hello!
I have two systems:
Home System = among other RPi2 & Domoticz last stable 3.5877 & RFLink R42 ...
Test environment = Win10 & Domoticz last beta (currently 3.6325) & RFLink R45 ...
I have several external temperature sensors for WH6 weather station WH0204.
Domoticz 3.5877 & RFLink R42 detects:
Type: Temp + Humidity
Subtype: WRTG800
Dates: 22.1 C, 0%, Bat 100
(The sensor does not contain humidity, but the temperature is OK and work very well.)
Domoticz last beta & RFLink R43-R45, the sensor does not find ...
Debug output from R42, 43, 44 and 45 is exactly the same!
R42
20; 13; AlectoV3; ID = 002E; TEMP = 00d9; HUM = ff; BAT = OK;
20; 14; AlectoV3; ID = 00fc; TEMP = 00dc; HUM = ff; BAT = OK;
20; 15; AlectoV3; ID = 00da; TEMP = 00e2; HUM = ff; BAT = OK;
R45
20; 5C; AlectoV3; ID = 002E; TEMP = 00d9; HUM = ff; BAT = OK;
20; 5D; AlectoV3; ID = 00fc; TEMP = 00 db; HUM = ff; BAT = OK;
20; 5E; AlectoV3; ID = 00da; TEMP = 00e2; HUM = ff; BAT = OK;
I want to upgrade RFLink R45 (because Unitec work there), but I can not ...
When I upgraded to R44 or R45 to the home system, but a lot of things not work because it did not go Thermometers.
Existing inoperative and is not new.
Where is the problem??? Domoticz or RFlink ???
Help anyone?
Thanx!
I have two systems:
Subtype: WRTG800
R42
R45
Help anyone?
Thanx!
