Domoticz on Synology sometimes crashes from Zwave stick
Posted: Sunday 08 January 2017 10:46
My Domoticz system (V3.5877) on my Synology NAS is usually working fine, but now and then (once or twice a week) it crashes and I have to manually restart it. When looking at the logs, it seems that it has something to do with my Zwave stick. Below are the last log lines from the crash last night:
Does anybody have any idea how to fix this?
Thnx, Sander.
2017-01-08 00:38:30.495 Error: Z-Stick hardware (7) nothing received for more then 1 Hour!....
2017-01-08 00:38:31.495 Error: Restarting: Z-Stick
2017-01-08 00:38:31.629 OpenZWave: Closed
[32m2017-01-08 00:38:32.629 Always, ***************************************************************************
[39m[32m2017-01-08 00:38:32.629 Always, ********************* Cumulative Network Statistics *********************
[39m[32m2017-01-08 00:38:32.630 Always, *** General
[39m[32m2017-01-08 00:38:32.630 Always, Driver run time: . . . 0 days, 1 hours, 14 minutes
[39m[32m2017-01-08 00:38:32.630 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 51
[39m[32m2017-01-08 00:38:32.630 Always, Total messages successfully received: . . . . . . . . . . 51
[39m[32m2017-01-08 00:38:32.630 Always, Total Messages successfully sent: . . . . . . . . . . . . 24
[39m[32m2017-01-08 00:38:32.630 Always, ACKs received from controller: . . . . . . . . . . . . . 24
[39m[32m2017-01-08 00:38:32.630 Always, *** Errors
[39m[32m2017-01-08 00:38:32.630 Always, Unsolicited messages received while waiting for ACK: . . 0
[39m[32m2017-01-08 00:38:32.630 Always, Reads aborted due to timeouts: . . . . . . . . . . . . . 0
[39m[32m2017-01-08 00:38:32.630 Always, Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
[39m[32m2017-01-08 00:38:32.630 Always, CANs received from controller: . . . . . . . . . . . . . 0
[39m[32m2017-01-08 00:38:32.630 Always, NAKs received from controller: . . . . . . . . . . . . . 0
[39m[32m2017-01-08 00:38:32.630 Always, Out of frame data flow errors: . . . . . . . . . . . . . 0
[39m[32m2017-01-08 00:38:32.630 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 0
[39m[32m2017-01-08 00:38:32.630 Always, Messages dropped and not delivered: . . . . . . . . . . . 1
[39m[32m2017-01-08 00:38:32.630 Always, ***************************************************************************
[39m2017-01-08 00:38:35.149 OpenZWave: Starting...
2017-01-08 00:38:35.149 OpenZWave: Version: 1.4-2246-ga583ba8-dirty
2017-01-08 00:38:35.149 OpenZWave: using config in: /usr/local/domoticz/Config/
[32m2017-01-08 00:38:35.151 Always, OpenZwave Version 1.4.2246 Starting Up
[39m2017-01-08 00:38:35.331 OpenZWave: Driver Ready
2017-01-08 00:38:35.333 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-01-08 00:38:35.333 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH TOGGLE BINARY, Label: Toggle Switch, Instance: 1
2017-01-08 00:38:35.333 OpenZWave: Unhandled class: 0x28 (SWITCH TOGGLE BINARY), NodeID: 6 (0x06), Index: 0, Instance: 1
2017-01-08 00:38:35.334 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-01-08 00:38:35.334 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH TOGGLE BINARY, Label: Toggle Switch, Instance: 1
2017-01-08 00:38:35.334 OpenZWave: Unhandled class: 0x28 (SWITCH TOGGLE BINARY), NodeID: 11 (0x0b), Index: 0, Instance: 1
2017-01-08 00:38:37.709 OpenZWave: Awake Nodes queried
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::thread_resource_error> >'
what(): boost::thread_resource_error: Resource temporarily unavailable
Thnx, Sander.
