Connecting HGI80 to Evohome v2
Posted: Saturday 07 January 2017 12:09
Can anyone tel me how to connect a Honeywell HGI80 to a Evohome V2 (none WiFi - Ver.25)?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
[ 15.010131] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ 15.185163] usb 1-1.3: New USB device found, idVendor=10ac, idProduct=0102
[ 15.185178] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 15.185186] usb 1-1.3: Product: TUSB3410 Boot Device
[ 15.185194] usb 1-1.3: Manufacturer: Texas Instruments
[ 15.185202] usb 1-1.3: SerialNumber: TUSB3410
[ 16.633972] usbcore: registered new interface driver usbserial
[ 16.634158] usbcore: registered new interface driver usbserial_generic
[ 16.634247] usbserial: USB Serial support registered for generic
[ 16.639613] usbcore: registered new interface driver ti_usb_3410_5052
[ 16.639771] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 16.643527] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[ 16.643697] ti_usb_3410_5052 1-1.3:1.0: TI USB 3410 1 port adapter converter detected
[ 16.643837] usb 1-1.3: Direct firmware load for ti_usb-v10ac-p0102.fw failed with error -2
[ 17.430124] usb 1-1.3: reset full-speed USB device number 5 using dwc_otg
[ 17.567063] usb 1-1.3: device firmware changed
[ 17.567211] ti_usb_3410_5052: probe of 1-1.3:1.0 failed with error -5
[ 17.568124] usb 1-1.3: USB disconnect, device number 5
[ 17.670318] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
[ 17.712422] fuse init (API version 7.26)
[ 17.860805] usb 1-1.3: New USB device found, idVendor=10ac, idProduct=0102
[ 17.860814] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 17.860819] usb 1-1.3: Product: TUSB3410 Boot Device
[ 17.860823] usb 1-1.3: Manufacturer: Texas Instruments
[ 17.860827] usb 1-1.3: SerialNumber: TUSB3410
[ 17.864134] ti_usb_3410_5052 1-1.3:1.0: TI USB 3410 1 port adapter converter detected
[ 17.864175] ti_usb_3410_5052: probe of 1-1.3:1.0 failed with error -5
[ 17.866271] ti_usb_3410_5052 1-1.3:2.0: TI USB 3410 1 port adapter converter detected
[ 17.867733] usb 1-1.3: TI USB 3410 1 port adapter converter now attached to ttyUSB0
crw--w---- 1 root tty 4, 8 Jan 11 21:58 tty8
crw--w---- 1 root tty 4, 9 Jan 11 21:58 tty9
crw-rw---- 1 root dialout 204, 64 Jan 11 21:58 ttyAMA0
crw------- 1 root root 5, 3 Jan 11 21:58 ttyprintk
crw-rw---- 1 root dialout 188, 0 Jan 13 21:46 ttyUSB0
lrwxrwxrwx 1 root root 7 Jan 11 21:59 ttyUSB.Evo0 -> ttyUSB0
crw------- 1 root root 10, 239 Jan 11 21:58 uhid
crw------- 1 root root 10, 223 Jan 11 21:58 uinput
crw-rw-rw- 1 root root 1, 9 Jan 11 21:58 urandom
2018-01-13 21:26:36.996 evohome: WARNING unrecognised message structure - possible corrupt message '00' (3)
2018-01-13 21:34:46.876 evohome: WARNING unrecognised message structure - possible corrupt message '000503BA' (3)
2018-01-13 21:44:41.791 evohome: WARNING unrecognised message structure - possible corrupt message '05' (3)
2018-01-13 21:49:30.752 evohome: WARNING unrecognised message structure - possible corrupt message '000503BA' (3)
2018-01-13 22:00:00.461 Starting automatic database backup procedure...
2018-01-13 22:00:01.639 Ending automatic database backup procedure...
2018-01-13 22:03:20.640 evohome: WARNING unrecognised message structure - possible corrupt message '00FFFFFFFFFFFF00' (3)
045 RQ --- 30:066831 01:064918 --:------ 0006 001 00
045 RP --- 01:064918 30:066831 --:------ 0006 004 000503BA
045 I --- 04:216971 --:------ 01:064918 12B0 003 000000
045 I --- 04:216971 --:------ 01:064918 2309 003 0003E8
045 RQ --- 30:066831 01:064918 --:------ 1260 001 00
045 RP --- 01:064918 30:066831 --:------ 1260 003 0013FA
045 I --- 04:027026 --:------ 04:027026 30C9 003 000802
045 I --- 01:064918 --:------ 01:064918 1F09 003 FF080C
045 I --- 01:064918 --:------ 01:064918 2309 027 0003E80103E80203E80303E80403E80503E80603E80703E80803E8
045 I --- 01:064918 --:------ 01:064918 30C9 027 0007E50106EB0207380306FE04088D0507300605DF0708020806D9
045 I --- 04:088267 --:------ 04:088267 30C9 003 0006E9
095 RQ --- 18:002741 14:139298 --:------ 1260 001 00
