Sending Sms (clickatell)  [Solved]
elmortero
Domoticz version: 3.9639
Post by elmortero »
Hi dannybloe,
Do you think it might be possible to provide a way to use domoticz.sms with a phone number as extra parameter?
Right now the function works fine, getting the credentials from the domoticz settings but there are some downsides:
* an sms can only be sent to the preset phone number (and only that number)
* as a concequence there is no way to send to different numbers when different condicions apply
* when using domoticz.notify, all activated notifications are used, so also sms
I have been trying to 'port' BakSeeDaa's methode ( viewtopic.php?t=7387) to dzvents, and also tried to call the function he provides from within a dzvents script but it fails a several levels
For now I use this method which allows me to deactivate Clickatell Sms in the Domoticz settings and thus avoiding an Sms being sent every time a notification is sent:
domoticz.openURL("https://api.clickatell.com/http/sendmsg?user="..APIUser.."&password="..APIPassw.."&api_id="..APIId.."&from=+"..Sender.."&to="..PhoneNumber.."&text="..SMSText)
This works fine but i have to declare the parameters everytime I want to use it in a different script.
It also lacks the advantage of the smsencode function that BakSeeDaa created for this.
I think would be useful to have such functions also available in dzVents, but without the need of all the uservariables (so maybe a config file would be needed, containing the needed parameters)
elmortero
Re: Sending Sms (clickatell)  [Solved]
Post by elmortero »
Having a free day today, I dug into this and found out how to add functions to dzVents. I based this on BakSeeDaa's info I referred to.
Thank you to BakSeeDaa for the investigative work and letting me use it!!
By adding the following lines to /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua I created two new Domoticz Methods:
	--this is where I use bakseedaa's encode function
	function self.smsEncode(str)
		-- Convert to GSM 03.38 character set and URL-encode
		local utf8Chars={"%%","\n"," ",'"',"&",",","%.","/",":",";","<","=",">","?","¡","£","#","¥","§","Ä","Å","à","ä","å","Æ","Ç","É","è","é","ì","Ñ","ñ","ò","ö","Ø","Ö","Ü","ù","ü","ß", "\\", "*", "'", "%(", "%)", "@", "%+", "%$", "%[", "%]", "%^", "{", "|",  "}", "~"}
		local gsmChars={"%%25","%%0D","%%20","%%22","%%26","%%2C","%%2E","%%2F","%%3A","%%3B","%%3C","%%3D","%%3E","%%3F","%%A1","%%A3","%%A4","%%A5","%%A7","%%C4","%%C5","%%E0","%%E4","%%E5","%%C6","%%C7","%%C9","%%E8","%%E9","%%EC","%%D1","%%F1","%%F2","%%F6","%%D8","%%D6","%%DC","%%F9","%%FC","%%DF","%%5C","%%2A","%%27","%%28","%%29","%%40","%%2B","%%24","%%5B","%%5D","%%5E","%%7B","%%7C","%%7D","%%7E"}
		for i = 1, #utf8Chars, 1 do
			str = string.gsub(str, utf8Chars[i], gsmChars[i])
		return str
	--here is the clickatell function
	function self.SendClickAtell(message, PhoneNumber)
	local APIUser = "YOUR_CLICKATELL_USERNAME"
	local APIPassw = "YOUR_CLICKATELL_PASSWORD"
	local APIId = "YOUR_CLICKATELL_API_KEY"
	local Sender = "YOUR_CLICKATELL_SENDERNAME_IF_YOU_USE_ONE"
	local EncMsg = self.smsEncode(message)
		self.sendCommand('OpenURL', "https://api.clickatell.com/http/sendmsg?user="..APIUser.."&password="..APIPassw.."&api_id="..APIId.."&from=+"..Sender.."&to="..PhoneNumber.."&text="..EncMsg)
sending a clickatell sms whithout having it configured in the Domoticz settings (and thus not sending smses when using domoticz.notify) goes like this:
domoticz.SendClickAtell("your message here", "destination phonenumber")
Where destination phonenumber is a single number or multiple numbers,separating them with a comma.
SendClickatell automatically calls the second new function smsEncode. This converts the message to a usable string for use in an URL. Without this for example I had to replace spaces in the message with %20
Right now the clickatell credentials is put in the Domoticz.lua file, I might change that later to Global persistent variables but I am not sure if there is any advantage in that.
Another advantage is that the destination number can be different in different scripts or under different conditions (or based on that be sent to either one or multiple destinations. For example: IF we are on vacation and front door is opened Then IF neighbor one is on call THEN send him an sms ELSE IF Mother in law is on Call THEN send her an sms (with different content..)
Hopefully this might be useful to someone.
Cheers,
olivier
dannybloe
Post by dannybloe »
Howee, I totally missed this post and by accident saw it yesterday when I discovered that the clickatell service in Domoticz wasn't working for me.
So, looked at this script and it gave me the exact same errors as the built-in service. So I did some digging and hacking on my own to get it to work and turns out that the URL and api seem to have been changed. So this is what I came up with. I created a dzVents helper function and a small dictionary of telephone numbers that I can use throughout my code so I have only one place where the numbers are stored and have to be edited:
Put this code in global_data.lua:
local phoneNumbers = {
    ['PersonA'] = '+31xxxxx',
    ['PersonB'] = '+31yyyyy'
local function smsEncode(str)
      return str
	helpers = {
        	sendClickatell = function(domoticz, message, user, phoneNumber)
	            local APIId = "<your clickatell API code"
	            local encMsg = smsEncode(message)
	            local number = phoneNumber -- optional
	            if (phoneNumber == nil) then
	            	-- get it from the list above
	                number = phoneNumbers[user]
	            local url = "https://platform.clickatell.com/messages/http/send?apiKey=" ..
	                APIId ..
	                "&to=" ..
	                number ..
	                "&content=" ..
	                encMsg
	            domoticz.openURL(url)
This one is actually better than the one before as you don't need to send your username+password.
Oh, and I don't think this should be built into dzVents as this is typically something you can put in the helpers section.
DewGew
Domoticz version: V4.10618
Post by DewGew »
dannybloe wrote: Monday 31 July 2017 11:11 Howee, I totally missed this post and by accident saw it yesterday when I discovered that the clickatell service in Domoticz wasn't working for me.
      return str
	helpers = {
	                APIId ..
	                "&to=" ..
	                number ..
	                "&content=" ..
	                encMsg
How do I call the helper from a script?
DewGew
Post by DewGew »
I tryed the above code with dzVents helper but i got this error
Error: /home/pi/domoticz/scripts/dzVents/scripts/global_data.lua:19: bad argument #1 to 'gsub' (string expected, got nil)
Any ideas?
dannybloe
Post by dannybloe »
you must call it in your script's execute: domoticz.helpers.sendClickatell(domoticz, 'Hi there', 'John')
DewGew
Post by DewGew »
Oh thanks. I missed that. Now its working :)
BakSeeDaa
Post by BakSeeDaa »
dannybloe wrote: Monday 31 July 2017 11:11 This one is actually better than the one before as you don't need to send your username+password.
Hi @dannybloe
After helping another forum member today with his script I've found out that the api version you are using in the example that you kindly provided is relevant to all Clickatell accounts created after 15 November 2016. That version supports UTF-8 and shouldn't be converted to the GSM 03.38 character set. Your script example needs to be changed. (The message still needs to be URL-encoded though.) I've seen that you will add support for URL-encoding in the next version of dzVents which is very nice.
This is certainly not related to dzVents by it might be interesting in this context to know that the Domoticz's notify functions is using the old API version for clickatell. (calling api.clickatell.com and using username + passord and a short numeric API-ID)
I believe Domoticz should consider to use the new Clickatell API instead so that Clickatell accounts created after 15 November 2016 can be used. I will make a ticket for that.
EDIT: There is already a ticket for this on gitHub.
