RFLink with FW that receive from RFLink with out FW
Posted: Wednesday 04 January 2017 12:04
by denisj
Hi there all,
I just receive 2 kits of the RFLink.
One of this I charge the firmware and I linked it to my domoticz raspberry and it's work great :-)
The other RFLink hardware (arduino + RFLink),
I want to use it in a garden project and I want to make my custom schetch on it, so I don't want to upload all library firmware on it.
So how can I use the hardware of the second RFLink to just send
via 433Mhs a "Hello world" to the first RFLink (domoticz) please ?
I need to upload just a lib in order to send/receive from Domoticz.
Thanks all
Denis
Re: RFLink with FW that receive from RFLink with out FW
Posted: Wednesday 04 January 2017 17:20
by NietGiftig
denisj wrote: I need to upload just a lib in order to send/receive from Domoticz.
You are sure?
Just a lib?
Then why don't you do that?
And then let us know how you did this, I'm very curious
Posted: Wednesday 04 January 2017 17:30
by denisj
I'm sure that just a lib can be suficent in order to make work the rf part.
But that's not the real problem... can be 2 or 3 or 4.
What I want is to use the second arduino+RFLink
for other projects and put my sketch inside.
Denis
Posted: Wednesday 04 January 2017 18:17
by NietGiftig
denisj wrote:I'm sure ....
Always good to read, no help nessecary then
Good luck
denisj wrote: and put my sketch inside.
What sketch ?
Posted: Wednesday 04 January 2017 19:14
by denisj
I will write a sketch in order to mantain my future hydroponic garfen.
And from the garden I will send statistics about PH, nutrient, water level etc... to domoticz.
Before to begin I want just to send a Hello World msg. to
domoticz server.
Thanks again
Denis
Posted: Wednesday 04 January 2017 20:37
by denisj
Now that I'm home I can show you a better sample:
#include <VirtualWire.h>
const int led_pin = 11;
const int transmit_pin = 12;
const int receive_pin = 2;
const int transmit_en_pin = 3;
void setup()
  // Initialise the IO and ISR
  vw_set_tx_pin(transmit_pin);
  vw_set_rx_pin(receive_pin);
  vw_set_ptt_pin(transmit_en_pin);
  vw_set_ptt_inverted(true); // Required for DR3100
  vw_setup(2000);	 // Bits per sec
byte count = 1;
void loop()
  char msg[7] = {'h','e','l','l','o',' ','#'};
  msg[6] = count;
  digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
  vw_send((uint8_t *)msg, 7);
  vw_wait_tx(); // Wait until the whole message is gone
  digitalWrite(led_pin, LOW);
  delay(1000);
  count = count + 1;
Did you see ? ...there it's just an include cmd... the "VirtualWire.h" one, so just one lib.
This lib use another RF hardware.
So what I want is to use something like this with the RFLink hardware,
for this reason I buy 2 arduino+RFLink hardware.
So is there is something also for the RFLink hardware ? in order to use it with out the complete firmware.
And yes... I'm sure can be done, but I don't know how with the Aurel Tranceiver... for this reason I ask on this thread.
If you don't understand what I want, just ask and I'll explain better.
If you understand what I want but you don't want to help, please don't make a bad jokes.
Thanks again
Denis
