Rfxcom lost transmission power
Posted: Tuesday 03 January 2017 19:35
by DutchHans
Good evening..
All of a sudden my transceiver seem to have lost power.. Previously it reached all adapters, plugs and valves around the house... Then suddenly it can't reach half of the amount... I thought a plug died.. But it concerned also pirs and dimmers.. Anyone had this before?..
I've updated to the latest firmware of the rfxtrx.. Also updated domoticz till the latest beta...
Can it be that the sd card is damaged?...
All tips are welcome..
Regards, Hans
Re: Rfxcom lost transmission power
Posted: Tuesday 03 January 2017 21:25
by DutchHans
Anyone?
Posted: Tuesday 03 January 2017 21:46
by SweetPants
Are you sure there is no device with low-battery? Some tend to transmit continously when low on battery, screwing up the RfxCom receiver. Especially PIR's behave like this.
Posted: Tuesday 03 January 2017 22:09
by DutchHans
Thank you, i will check
Posted: Tuesday 03 January 2017 22:34
by DutchHans
Changed batteries in two (most active) pirs.. No changes..
Posted: Tuesday 03 January 2017 23:25
by DutchHans
Checked some other pirs..you might have a point.. I can't check today anymore... I will give it a try tomorrow...
Posted: Wednesday 04 January 2017 8:02
by Egregius
Actually basic knowledge about the 433 stuff that they spit continously when battery is low. If you had searched the forum or Googled you could have found that faster than your bump after less than 2 hours
Posted: Friday 06 January 2017 14:22
by SweetPants
DutchHans wrote:Checked some other pirs..you might have a point.. I can't check today anymore... I will give it a try tomorrow...
and????
Posted: Tuesday 10 January 2017 14:04
by OneOhEd
I seem to be suffering from the same issue. Been working fine for years but suddenly my RFXcom isn't properly receiving sensors (PIR, door contacts, etc). Tried updating RFXcom (Ext2 firmware 1012) but now it receives ALMOST nothing... (no PIR, contacts, etc and most switches).
Very frustrated - been replacing batteries too... no luck
Posted: Tuesday 10 January 2017 14:30
by b_weijenberg
See chapter 15.1 in the RFXtrx User Guide
Posted: Monday 30 January 2017 12:16
by Bernd
I found out, with a little scanner on 433,92 MHz, that sensors start to generate a continuous RF signal when their battery is getting low, blocking the RFXCOM signal in their neighbourhood. Make sure that all sensors have proper working batteries!!!
Posted: Thursday 03 August 2017 23:24
by sbjbjoer
Hi i had brakedown on my secont rfxcom433e after lightenibg storm eaven if det storm was not too near seems like det receiver damaged it sends comands ok any see this problem
Posted: Friday 04 August 2017 11:54
by b_weijenberg
sbjbjoer wrote:Hi i had brakedown on my secont rfxcom433e after lightenibg storm eaven if det storm was not too near seems like det receiver damaged it sends comands ok any see this problem
Transmit power is OK.
It is possible that the receiver is damaged by a lightning pulse.
Please check the RFXtrx on another location >500 meters away from the current location and check with RFXmngr on a laptop if you receive a sensor with a normal range.
If the RFXtrx is defect contact support rfxcom.com for a possible repair.
Posted: Tuesday 31 December 2024 12:39
by Jamboman
I can confirm Bent’ experience. A faulty KAKU motion detector (possibly on weak batteries) blocked several KAKU receivers nearby from responding to ON /OFF signals. When I removed the batteries all of a sudden the issues were over.
